Old 16th July 2016, 10:34 AM
daandaman daandaman is offline
I sold the car over a year ago, but from memory just like this...
vs the OEM one which looks like this
So when you installed it, the trailer connector just plugged in, and the wiring loom also plugs in, and on the car end you need to push some pins into the pre-wired/fused fusebox?
edit: why the F* does everyone just cut off these looms... what do they expect you to do with just the box on ebay 8-|
Old 16th July 2016, 10:46 AM
Two plugs to the trailer control unit, a few connections to the fuse box and also a couple of pins to other control units - all in the PDF instructions I attached earlier.
I suspect it is an economics of breaking a car thing, pulling out looms costs more than they are worth
Old 6th October 2016, 05:35 AM
So all is installed as per factory/oem. I'm just missing 3 fuse holder crimp connectors (the ones that you push into the rear of the fuse holder next to the boot motor).
Has anyone got the part number for these separate crimp connectors?
