Old 17th July 2016, 07:54 AM
kele kele is offline
Default Auto lights
Having an issue with auto headlight activation. I have to manually switch them on and off. In auto setting they remain permenantly off ( no matter what the light levels )
No error codes anywhere.. Yet the dash backlights will brighten and dim according to ambient light. Fuses all ok too. So I was thinking light sensor in the mirror housing but confused that the dash backlights are responding to the levels of ambient light? Any ideas?
2012 A6 3.0 TDI Avant, Silver, 7 Spd STronic, Bose, ACC, Advanced Parking Camera, Power close / open tailgate, Side and Lane Assist, AMI & Jukebox, Adaptive lights with corner and high beam assist, Through load with ski bag, Audi pre sense plus, sports diff and sport suspension, Panoramic roof, Storage pack, MMI touchpad and VIM, etc. Oh and now retro fit rear seat entertainment
2019 BMW I3. Heat pump, Winter, professional and comfort packs, Harmon Kardon, autopilot
2022 Mercedes EQC 400
Previously: 2009 S8, Silver, B&O, Ceramic Brakes, Advanced Parking Camera, VCDS
2008 A8 3.0 Tdi sport, B&O
Old 17th July 2016, 10:42 PM
mcs's Avatar
mcs mcs is offline
The dash lights respond to ambient light anyway as there is a sensor in the instrument cluster for them.
If the auto activation only has died, I would be replacing the switch and seeing if that is the problem.
It is easy to remove, just look for video instructions for removing any VAG headlight switch.
Mike
04 A8 - 4.2 Sport
Indigo Leather Sports Seats - Sports wheel - Sports Air Suspension
Auto Boot - Double Glazing - AMI - Solar roof
TV - Bose - Voice Control - TPMS - AFS- TINT
Power Blind, Fingerprint - Light package (in and out)
Retrofits:
OEM Auto headlights & rain sensing wipers
OEM Bluetooth phone
Bluetooth Audio Streaming
Reverse Camera
OEM Aluminium Package
Auto boot close using remote/door button
Old 18th July 2016, 08:29 PM
Yes, switch sounds a good place to start - Also try switching it each way aggressively if not change, take the switch apart and clean it with a tissue and some alcohol before replacing - there's not much to go wrong.
Old 21st July 2016, 09:03 AM
Storka's Avatar
Storka Storka is offline
May need a new gel pad behind the light sensor on the windscreen
