Disconnect the battery, you could do it without disconnecting it but it makes your life a whole lot easier, it's pretty much remove everything then unbolt the frame swap the unit over and bolt back together, just make sure you get the in and out the right way round on the fibre otherwise the mmi will throw a fit
