Old 2nd June 2016, 10:25 AM
think he had then powder coated IIRC
HERE is the thread for what he did
Old 1st October 2016, 03:59 PM
RS6's Avatar
RS6 RS6 is offline
You could always get the trim chrome wrapped
Abarth 500 Esseesse - Sold
RS6 Avant Black - Stolen
Mercedes Benz CLS 500 - Sold
Corsa VXR Nurburgring - Sold
RS6 Avant Grey - Sold
Seat Leon Cupra R - Sold
Old 6th October 2016, 07:18 PM
Joe2.0E Joe2.0E is offline
Sounds like a good option. Any photos of this done ?
Old 19th October 2016, 10:11 PM
Ameiseuk's Avatar
Ameiseuk Ameiseuk is offline
May be an option here, ive just spent the last couple of hours cleaning up the rear bumper chrome trim.
Gave it a rub down with 1200 grit wet n dry, followed by a liberal application of Alumagic paste.
A quick buff down with microfibre cloth seems to have cleaned it up.
How long it lasts is anyones guess
Daily drive:
Current 'Project':
Previous 'Projects':
2000 Audi S8 FL
www.whall.co.uk
Old 3rd November 2016, 09:32 PM
aTOMic's Avatar
aTOMic aTOMic is offline
Seems I remember boiling in simple H2O will cause a surface layer of aluminum oxide to form - a very durable substance. Only trouble is it's a matte gray finish AFAIK.
Yes in the US I bought some "Air Conditioner Coil Cleaner" liquid which turns out is simply a strong sodium hydroxide (lye) and water solution. It foamed up madly and removed 40 years' worth of dirt from my evaporator and condenser coils on the home HVAC, and shined up my dear departed Granma's espresso (moka) pot. Can't one buy lye drain opener in the UK?
Haven't experimented much with it as it requires full protective gear which is HOT and cumbersome in the Tennessee heat... and I actually heed warnings to the point of buying a $90 respirator w/ organic vapor filter for this job. Along with industrial rubber sleeve gloves, face shield, etc.. Having worked on an ambulance here in "Hey man, hold my beer and watch this!" country, I've seen some things...
I'm in love with a car.
2004 4.2L Petrol A8L
Sage Green/Black (one of only five D3s thus colored sold in the US)
Old 4th November 2016, 01:23 PM
Yes you can get Sodium Hydroxide drain cleaner here. some have recommended it for cleaning the drains in the scuttle (probably called something different in USA ) but I am not sure I want it near paintwork even under the bonnet(hood) as is (obviously) caustic. By the way, how did the coffee taste?
Old 4th November 2016, 01:45 PM
HPsauce HPsauce is online now
Aluminium and Caustic soda is a VERY VERY BAD IDEA! https://www.youtube.com/watch?v=FdRrZH3M5O0
Old 4th November 2016, 02:05 PM
But look at how CLEAN it is!!
That could be your body work.........
Old 5th November 2016, 06:21 PM
aTOMic's Avatar
Coffee was fine; in fact the reason I researched how to treat the "raw" aluminum (aluminium* to you guys) was prevent any metallic taste - before I cleaned the 100-year-old pot, which had a layer of mineral buildup in the bottom (remember a moka pot boils dry each time)nothing would (chemicallly) touch.
I don't know what the US equivalent of "scuttle" is ("Sump?) however I do know what the word means, but I know VWs and Audis have a definite problem with their (scuttle) drainage!
*My wife is from Germany, moved to the US when she was 13; when I met her 20-odd years ago, she could not say the Al word either way; especially funny since she has two Masters' degrees - and one is biology! (A good old science joke here is to have someone say "aluminum" ten times as though it were a tongue-twister, then ask them what a tin can is made of)...
You are correct, sir; as I said...
...it requires full protective gear... ...and I actually heed warnings to the point of buying a $90 respirator w/ organic vapor filter for this job. Along with industrial rubber sleeve gloves, face shield, etc.. ...
In any case I have misunderstood the question - OP is talking about the plastic strips, and I was thinking of the removable window trim that is worn-looking on so many of our cars. I have always wondered how they chrome-plate plastic (assuming they do). There was an episode of "How It's Made" (Canadian TV series) which detailed the process IIRC.
Last edited by aTOMic; 5th November 2016 at 08:04 PM. Reason: Grammar, info added, clarity, etc.. OK?
Old 4th October 2017, 03:32 PM
I think it's made from polished aluminium with a lacquer coating on top, and water is penetrating between. So any surface treatment is doomed to failure.
I had a little experiment today and now think there are two problems, one of which is sort of fixable.
I've seen comments about people polishing the trim with just WD40 and have tried that myself. It works in some areas but not others.
Thinking about it, where it works the damage must be mainly on the surface, so I tried a test area with a thin layer of lacquer topcoat, having cleaned it thoroughly first and it worked quite well. It's the small shiny area in front of the mirror pivot in the first picture below. That trim on the drivers door is only slightly milky.
I think a fair bit of the trim on my car is just affected by surface degradation, so I plan to treat all of it, in stages, with clear lacquer.
I know some bits (notably the trim under my offside headlight) will not be improved much by that, but I'll give it all a go eventually, I don't have enough lacquer on hand at present to do anything other than small tests.
The second picture shows that headlight trim, it was all milky but I treated the centre and right areas. The right improved a lot but the centre highlighted the deeper damage that is shown by the obvious milky streaks.
ID:	17145   Click image for larger version
Tags
chrome, discoloured, oxidised, plastic, tarnished
