Very grateful for all the figures and input.
I've come to the realisation that I can probably afford to maintain an S8, but not to put fuel in it! After budgeting for everything else including my Audi A3 I'd only have enough realistically to pay for 4000 miles worth of fuel per year. That's based on 19.2 mpg, though if I drop to 15mpg, then it's 3000 miles. Gorgeous cars but not worth the outlay in my case with so few miles ![]() I still want one despite it being ruinous ![]() |
I'm lucky in that I'm self employed and bill clients at 45p a mile so I am quids in on fuel, but if my situation was different I couldn't justify the cost, however, don't let this put you off, have a look at the 4.2 TDI - it might pleasantly surprise you, and a test drive is free
For the cost of this S8 I am just into D4 territory. I hadn't realised that the 3.0 TDi's were so quick compared to the D3 3.0 TDi's. Found two near me which look promising: http://www.sytner.co.uk/car-search/6...-4dr-tip-auto/ http://www.ttsportsandprestige.co.uk.../aetv20138252/ |
Hi Kev,
Another viewpoint for you on running and enjoying an S8. Service and Consumables Long life service every 15000 miles £400 except at 60,00 mile intervals where allow £600. Tyres - 10- 12000 per set, allow £250/corner. Brakes - assume disks every 60000 miles (£400) and pads every 30000 miles (£300). Typical faults- why you buy a warranty and don't use a stealer Typically around 80,000 - 120,000 miles you will get suspension compressor failure (generic A8 D3, not just S8), assume £300 with repair kit. If you are unlucky, power steering pump failure , assume £2500, engine out job. Buy or borrow a copy of VCDS and find a good indy mechanic who knows how to fault find and learn to live with some none impacting messages. Driving and engine comparisons Ian (IT) will be along to give you the best view of 5.2V10 vs. 4.2TDI vs. 3.0 TDI in D3 and D4, but nothing matches the noise and zing of the throttle response (light flywheel equivalent) of the V10. After over 4 years and 100,000 miles, it still gives me a buzz! S8s were well specced originally, compared with some others, so if you like the toys, you get more as standard on an S8. Plan on 20 mpg out of town and 15 mpg around the houses. But with 8000 miles a year, not that much difference even vs. 40 mpg diesel. Good luck and good hunting Richardracer ps fun on track, see ADI pictures!! Not much accelerates faster, but corners are a whole other story.....
My figures are for steel brakes. Consumables should not be required in first 200,000 miles for ceramics but if they do, very very expensive (£5k plus).
Not to pick holes in what Richard said, but the £399 I quoted is for the 60K service, 10 spark plugs, filters and a small OPEC countries daily output of oil
