Personally, I wouldnt waste the money on them.
I had one of them replaced for free under warranty one time my old D3 3.0TDI was in for a service. I did'nt notice any difference before of after. Obviously it will throw a fault code but I can live with that. |
You can avoid the fault-code by disconnecting the mounts and plugging in resistors sold by Audi themselves
I have replaced these type of mounts ...........hydro oil , vaccum type, viscous type on various models ...jags , mercs ,volvos .....ive not been able to tell a blind bit of difference driving and to drop subframe or flap about lifting engine up i just dont think its worth the agro , but its your call .
Lee, That sounds like god advice.
Does anyone have details about this Audi resistor mentioned earlier?
Rubber breaks down, like all bushes and needs replacing and these being hydro they can leak. The error might be a premature warning and they don't need replacing at all but they will need replacing at some point. Surly putting a resistor in is like turning the stereo up when your front arms start to knock?
Good point Scott, but I am thinking a visual check of the mounts would suffice.
[quote=ScottD3;123670]Its still a rubber mount, ignoring the electronic side of it.
Rubber breaks down, like all bushes and needs replacing and these being hydro they can leak. The error might be a premature warning and they don't need replacing at all but they will need replacing at some point. Surly putting a resistor in is like turning the stereo up when your front arms start to knock?[/QUo:TE] If its a subframe drop to do them better do the subframe mounts whilst your there .......then rear subframe .....then every suspension arm then anti roll bar ..... ![]() ![]() |
I've removed a set from a breaker and I don't recall it needing to drop the subframe. As the mounting faces was flatish, all you have to do was remove the bolts, support the engine and lift a little, slide the mounts out and replace. relatively easy job. I had the sub frame drops, front or rears. Trying to align them so they are correct is a bitch!!
Well ......if they are not to bad to do, go for it
![]() I just got an error code on my 2005 D3 I'm a bit curious how, if audi has put resistors in....or if the mounts on mine are real they've lasted THAT long!!! I've had the car for some years and 40k+ miles
Current : 2005 A8 Sport 4.2 V8 D3 - LPG working! Previous : 1998 S8 PF 4.2 V8 D2 - Gearbox died ~120k 2002 S8 FL 4.2 40v V8 D2 Prins LPG - Engine valves met pistons ~230K Also : 1996 Jeep Grand Cherokee 4.0l (Post Apocalyptic makeover) 2003 Brabus Smart FourTwo (should sell) 2003 Mazda Rx8 2.3 (might sell) |
