Old 20th May 2017, 04:10 PM
richardracer richardracer is offline
Talking Hybrid tuner not picking up signals?
Hello ladies and gentlemen,
For some while now (possibly since my upgrade to 5570) my hybrid TV tuner has not picked up any signals and just shows a fuzzy grey on the display. The search up and down does not find any channels. I have run VCDS which shows no faults and has coding of 0000003 in address 57. I have checked the antenna leads into the unit in the boot as well as the other cables.
It used to work fine. I could sit in Heathrow waiting to collect my daughter and pick up BBC2 or ITV with excellent signal. However, not used much and may have done 5570 upgrade since then, not sure.
3 requests of the experts out there please:
1. Does anyone know the VCDS security code for module 57 (TV) ?
2. Could some kind person with a D3 using a hybrid TV tuner please check module 57 and see what their coding shows (compared with my 0000003)
3. Any other suggestions for what might be wrong and how I might trouble shoot it?
Thanks in advance for any help
Richardracer.
2006 Audi S8 V10 Now Sold. Akoya Silver with black/grey leather, standard 20" wheels, hybrid TV, Bang & Olufssen audio, Heated seats front and rear, Dension ipod integration, DAB radio, keyless entry, rear electric blind, bluetooth connection to Apple iphone6S. Started at 60,000 miles end April 12. Now 171,500 miles as at Oct 2017. Now sold to fellow forum member.
Old 20th May 2017, 04:39 PM
Somerandomguy's Avatar
Heres my coding
Address 57: TV Tuner Labels: None
Part No SW: 4E0 910 148 E HW: 4E0 919 148
Component: R0078 TVhybridT 0470
Revision: R0H06000 Serial number: 76300800385702
Coding: 0000001
Shop #: WSC 02313 785 00200
VCID: 2545F5A79721
No fault code found.
The tuner also displays diagnistic info, incuding signal strength, on the tv display if you have it on when you open the TV module in VCDS which may provide some hints
Old 20th May 2017, 05:37 PM
Default Hybrid tuner not picking up signals?
Hi Somerandomguy,
Thanks for your coding info. I will give it a try tomorrow. Do you have the VCDS security code to update that code by any chance, hovering in that module does not reveal security code like some other places.
Regards
Richard
Old 20th May 2017, 06:22 PM
No, sorry, no idea what the security code is
Old 20th May 2017, 08:03 PM
EDIT, this is wrong see my later post -I bought my TV from an Audi S4 and the coding was for different antennas, after researching, I concluded 101 was for our cars with 4 diversity antennas.
Component: R78 TVHybridDVB 0470
Revision: R0H06000 Serial number: 76300801681001
Coding: 0000101
Shop #: WSC 06337 000 00000
VCID: 254A7831ECB7901605-8070
Old 21st May 2017, 02:06 PM
Default To vcds codes
Hi Snapdragon,
Thanks for your advice. Do you have the security code which allows me to change the coding?
Thanks
Richard
Old 23rd May 2017, 01:23 PM
Coding: 0000101
Interesting, Snapdragon!
I have saved a number of logs from A8s and none of them seem to have Coding as 0000101 for the Hybrid or Analogue TV. [That code implies an A6 Avant or a Q7 receiving Central European TV signals].
Most are 0000003, which my [analogue] one has too.
This is the format of the ECU coding:
Coding is 000abcc [corrected 15th June - thanks for the 'reminder' Ray!]
a - RSE - 0=no RSE or Inactive RSE, 1=Active RSE [Rear Seat Entertainment]
b - Aerial type - 0=A6 Saloon/A8 1=A6 Avant/Q7
c - Country - 03=UK/IRL PAL I : 01=Central Europe PAL B/G
Julian
Audi A8 3.0TDi MY2016 in Nautilus Silver.
Audi A8 3.0TDI MY2005 in Midnight Blue. Gone since 2018, after 10 years!
Old 15th June 2017, 11:10 AM
From what I can work out from VCDS, this is the coding:
Coding is 0000abcc
Julian
Thanks for that - I will try this coding now - I don't remember needing a security code, so will be able to test that theory at the same time.
Old 15th June 2017, 05:17 PM
Here is my coding:-
Address 57: TV Tuner Labels: 4E0-910-146.clb
Part No SW: 4E0 910 146 G HW: 4E0 919 146
Component: TV analog TUNER H12 0300
Revision: 00000085 Serial number: 00000000002193
Coding: 0001003
VCID: 2541DDA1EC046B093CD-8070
No fault code found
Note three leading zeros, not four.
Old 15th June 2017, 05:57 PM
Mine is slightly different:
Revision: R0H05000 Serial number: 76300700566602
Coding: 0000003
VCID: 25411E01EC6EF8162D-8070
