Old 2nd July 2017, 10:32 PM
Lee S Lee S is offline
Originally Posted by Turbo Tony
When it stops at around 10 mph, check your driver info display to see if that matches the time the gearbox is shifting down to 1st.
I will check that Tony, yes, but I think it doesn't shift down to 1st until really low, like 5 mph or something, maybe even lower. I will try it tomorrow to see. I have done about 180 miles in it over the weekend and to be honest it doesn't seem to be getting any worse. Looking back, it seemed to have started around the time of that really really hot weather, when it was about 28-30 degrees for a couple of days. Maybe coincidental. It's just been in for a longlife service and a couple of other odd jobs to Audi and they didn't comment, so we will see. Thanks all.
Lee
2017 Nissan Leaf Tekna
Old 3rd July 2017, 07:58 PM
It's still in 3rd (sometimes 2nd) when slowing down to 10 mph and only really drops into 1st if speed is like 2 or 3 mph or I stop. So 10 mph is not really related to a specific gear.
Lee
Old 4th August 2017, 11:47 AM
The behaviour sounds like the prop centre bearing, but the mileage is very low for that to be happening.
Old 4th August 2017, 08:17 PM
Pug Pug is offline
Did you ever get to the bottom of it?
Current: MY2019.5 Ford Ranger Wildtrak 2.0 BiTurbo
A8/S8 - A gap to fill.
Multi-Franchise Main Dealer during the day, Amateur vehicle enthusiast by night.
Old 7th August 2017, 12:23 PM
Well to date, the noise has gotten a little louder, but nothing has exploded or fallen off yet.
I have replaced all 4 tyres and that made no difference whatsoever.
I have taken the car to Chester Automatic Transmissions who got the car on the ramps, dipped the oil in all of the diffs and took it for two separate test drives and they are convinced that it is not gearbox/diff/prop shaft noise. In fact they said for the mileage, the car drove very smoothly and quietly apart from this overrun noise. They were perplexed and said it was something they had never heard before.
The noise appears to come from around the steering column area and is purely road speed dependant and not engine speed dependant. They did not discount that it could be something like a CV joint or wheel bearing but said that it would be noisier going round corners/tight turns, which it isn't.
Sometime this coming week I plan to get the car up on the jack and test the wheel bearings myself. This is the only thing I can think of. Unless anyone else has any more ideas.....
Lee
Old 5th September 2017, 10:42 AM
I'd have guessed at wheel bearings or even tyres, sometimes tyres can be responsible for the strangest road noises you will ever hear. If you have any spare winter wheels and tyres then swap them over and try on the same stretch of roads you're getting the noise on and see if it goes or not, an easy one to then eliminate tyres (have you checked tyre pressures too?)
Old 21st February 2023, 08:16 PM
Exerqtor Exerqtor is offline
Jumping on this since i've started experiencing this same noice/whine in my 2010 A8L D3 Quattro. I've had some other weird issues best described like driving a car with a sloppy dual-mas flywheel, like it's som extra slack/play somewhere in the driveline. And now i get this whining noise if i let of the gas and let the car "brake" on the gears. It's a a rather low milage csr with only 150k km, and I've owned it since 2014 / 100k km and driven it's newer pulled a load or been abused.
I changed the tranny fluid at 120k ish, so it's somewhat unexpected that it's started behaving like this.
Anyone else had the same issue?
I can also add that it's somewhat slow/rough shifting between 2nd & 3rd. Nothing wild, but enough that it's attention annoying. I've been dragging out to sort this out for a while, but seems like i have to do something now (car mechanic, and hate working on my own "crap" &#128518.
2010 D3 A8L 3.0 TDI QUATTRO
BI-Xenon Headlights, Keyless, Bang&Olufsen, DTV, DAB, Rear Camera, BT, TPMS, Soft Close, Auto Boot, AMI, 4 Zone AC, Home Link, All Electric Blinds, Ski Hatch, Black Extended Leather, Seat Memory on Both Sides, Heated / Cooled Sport Front Seats, Electrically Adjustable Rear & Heated Rear Seats Alacantra roofliner, Exterior LED Package, Lane Assist, Adaptive Cruise Control & Heated Steeringwheel ++.
