Just recalling the initial failing...
Id been in to a car partk for an interview. Had obviously detailed the car over the nights before to look as s****y as me! ![]() Over the coming days, a pattern developed. It will take up drive in reverse without issue. The first attempt at forwards drive was always met with the thump - but you learnt to soften it. Very slow and sensitive raising of the revs to around 1800 (i think) and tickle it and it would more gently drop in to drive. Then it was parked up and the investigation put on hold after the gearbox man condemned it with a potential £2500 rebuild price (which I appreciate isnt extortionate for this type of work) Today, I have had a photo sent of the gearbox ecu (Im presuming on the bulkhead) and the pins are sparkling clean. I have passed on the rest of your great advice and see how it all develops. Thanks again folks, Paul ![]()
Usually huffing, puffing and buffing in a dark corner somewhere... |
well MJ is the expert but even she concurs with the possibility of it being the dreaded F125
suffice it to say that you cannot be far from our sponsors and , one of those new being an arm and a leg , if it comes to it our hosts here would be able to provide a used one, I presume being PF it will be the one with the circular connection not the oval |
F125 from our sponsors is just over £100 used. The big problem is the work required to fit it.
A. New f125 is £165 from TPS and is worth it given the fact that all these switches will be a few years old and will.have started to degrade. With the costs of installing it on top, I would recommend a new one.
I guess it depends if you're doing it yourself and how much time you have.
If I was in DIY mode and not in a rush I'd take the old one off then take it apart and have a look inside before doing anything. IIRC wasn't it MJ who did that, found crud/corrosion etc. and just cleaned it up and reassembled/reinstalled and it was fine. But yes, if you're paying for the labour you might as well buy a new one. ![]()
I disagree its the F125 in this case - wrong fault codes. I only mentioned the F125 as a possible electrical cause of limp/thump rather than it always being mechanical.
The codes say something electrical inside the sump to me. For the record, I have known-good F125s that I am happy to lend to people for diagnostic purposes. If you can change it yourself its worth a try before spending £250 on a new one, but if you have to pay a garage just put a new one on. |
[quote=David's8;136897]A. New f125 is £165 from TPS and is worth it given the fact that all these switches will be a few years old and will.have started to degrade. With the costs of installing it on top, I would recommend a new one.[/QUOTE
~I have a tps just up the road and they quoted me over £300 for one as I wasn't a trader |
[quote=oldnick;136916]
![]() That said, I did ask earlier if those codes had been cleared and which returned after a short drive. Or even after a failed attempt at forward motion?
2003 D2 FL S8. Irish Green Pearl/Beige. Solar sunroof, auto-dim mirrors, electric rear seat functions and extended leather. Ski hatch retrofit. Aftermarket reversing camera. DVB-T and XCarlink now removed as redundant. 2016 Volvo V40 T5 Cross Country (4WD) with ALL the toys including adaptive cruise etc. etc. Osmium Grey with Blonde/Charcoal leather interior. Polestar performance "optimisation". ![]() ![]() Finally: gone, but not forgotten..... 1998 D2 PF S8. Agate Grey/Platinum. Every option (I think) except electric rear seats, Tiptronic steering wheel, ski hatch, towbar & dimming door mirrors. e.g. Cruise control, NavPlus/TV, Bose, GSM, Xenons, Solar roof, Parking sensors, Alcantara/leather everywhere of course. ![]() 1998 (very early) Ford Focus 1.8 Zetec; ABS/TCS, Heated screen/mirrors, Aircon. Added Auto-dim mirror, Leather seats, Trip computer, Cruise control, OEM Ford SatNav with CD changer. And before that a lot of Rover 800s, a few oddities, a lovely Triumph Dolomite 1850HL with Overdrive and way back in my schooldays an Austin Seven aka Mini 850! Last edited by HPsauce; 21st January 2018 at 02:48 PM. |
