Old 20th June 2018, 10:07 AM
Chip2786 Chip2786 is offline
Certainly my interpretation of that message is that it thinks the phone interface module is missing. Does it appear on the VCDS scan and can you communicate with it?
Mine would attempt connection but failed every time
Jobs done so far;
Fitted an RS Steering Wheel, Fitted 15mm wheel spacers, Lowered 10mm with VCDS, Reinstalled factory DVB, Unlocked VIM, Updated MMI to 5570, Fixed Factory Bluetooth Phone, Fitted heated fan-spray washers, Installed Bluetooth DAC For Audio, Added projection Puddle lights, Wind Deflectors, Fitted Apple TV to all 3 Screens, installed car WiFi, Fitted Custom vortex Exhaust
Old 20th June 2018, 11:17 AM
The MMI believes the module isnt installed....
Its possible, but unlikely you can talk to it via VCDS... If you can, then maybe unplugging and replugging might reset something, but I think its a long shot.
Due to its location, if you have a A/C or sunroof leak, its one of the first modules to get soaked.... then people remove or loop them out rather than coughing up for a new module at Audi money...
Old 20th June 2018, 04:57 PM
I managed to get a used BT Module for the RS6 for around £150 IIRC from ebay, needs the seat out to fit on mine though not sure on the S8
Old 20th June 2018, 05:02 PM
Shouldn’t be a seat out jobby, I can get to mine with it rolled back
Jobs done so far;
Old 20th June 2018, 09:11 PM
homer simpson's Avatar
Are these cars OK to disconnect the batteries to or is there a chance the electrics can play up? I know they probably throw up ghost faults but that's not a problem. If they are safe to disconnect then I would perhaps try that first?
Old 20th June 2018, 09:17 PM
C6 and D3 both have their phone modules under the passenger floor....
.... both can be got to with a little effort with the passenger still firmly in place.
My bet is still that its missing or been looped out.
If the unit goes faulty, it dies and breaks the MOST bus, so the whole MMI goes off.
For it to break enough to report as not installed, but not enough to break the fibre loop seems like a long shot to me...
There is no coding to enable a module either, if its on the most bus. It boots and becomes part of the system. Its really pretty fool proof......
Old 21st June 2018, 04:52 AM
Mine did
Jobs done so far;
Old 21st June 2018, 04:49 AM
I wouldn’t if you can avoid, my car went mental when the battery went flat. It threw up about 30 odd fault codes. They all cleared but scared the schnitzel out of me!
Jobs done so far;
Old 14th April 2019, 08:11 PM
Conquistador's Avatar
So this must be the telephone module in question, with the aforementioned large plug.
And a picture of the scary amount of electronics under the passenger carpet (which are under a polystyrene panel, upgraded from the D2's wood panel ), as well as centre console drain.
Currently '8-less
Previously:
- D3 A8 3.0 CVT
- D3 3.7 V8
Old 15th April 2019, 12:00 AM
H-M3 H-M3 is offline
What’s the symptoms of that drain plug? How do you clear any blockages then?
Audi A2 1.4 petrol 2002
NO VCDS rely on Neeldub
