Just Fitted a Fire TV On MMI 2G
I had a spare input on my digital tuner so I thought I’d stick at Fire TV in it. It works amazingly and now I have built in Netflix, Kodi, Apple Music, iPlayer etc. On all 3 TV’s Proper chuffed with it.
Here’s what I needed; AV in cable https://rover.ebay.com/rover/0/0/0?m...2F381575113139 4G Router and SIM card Huawei E5577 Black 4G Low-cost Travel Wi-Fi, Super-Fast Portable Mobile Wi-Fi Hotspot – Long-lasting Battery https://www.amazon.co.uk/dp/B011YM0O..._vTxlBbDCR7CJA HDMI to Composite adapter (I had one of these in stock but this should do) https://www.amazon.co.uk/dp/B01N5KNF..._EXxlBb4MGJPCF And 2 of these 12v to 5v converters https://www.amazon.co.uk/dp/B00G890M..._L2xlBbMZYJ8R9
Audi S8 D3 07MY 5.2 V10 Daytona Grey With Bang & Olufsen Advanced Sound System, Advanced Parking System, TV Analog/ Digital, Rear/Back Window blinds, Front and rear heated seats, Alcantara Roof, Extended leather Pack 2, Extended Aluminium pack, Carbon and Aluminium trim packs, RSE, PS2. Jobs done so far; Fitted an RS Steering Wheel, Fitted 15mm wheel spacers, Lowered 10mm with VCDS, Reinstalled factory DVB, Unlocked VIM, Updated MMI to 5570, Fixed Factory Bluetooth Phone, Fitted heated fan-spray washers, Installed Bluetooth DAC For Audio, Added projection Puddle lights, Wind Deflectors, Fitted Apple TV to all 3 Screens, installed car WiFi, Fitted Custom vortex Exhaust |
No idea why 2 of the pictures are upside down
That’s cool any chance of getting some wiring pics? I have 3 of those cables not sure what colour pins go where on the dtv
If you have a continuity tester it’s easy enough to figure out which pin does what, then you just use the attached pin outs on the DTV plug
Hello Chip, I like what you have done.
Do you have any audio whine/hum whistle (ground loop feedback). I do and I'm using a bluetooth receiver on AV1 and a MOTOVIEW airplay/chromecast on AV2 and was wondering if your power supply would be better than my USB cigar adapter. |
There is a slight high pitched hum when no audio is playing but it’s not Audiable when something is Doesn’t the cig socket stay powered all the time? If you are getting a ground loop you could try this? https://rover.ebay.com/rover/0/0/0?m...2F250489744414
Audi S8 D3 07MY 5.2 V10 Daytona Grey With Bang & Olufsen Advanced Sound System, Advanced Parking System, TV Analog/ Digital, Rear/Back Window blinds, Front and rear heated seats, Alcantara Roof, Extended leather Pack 2, Extended Aluminium pack, Carbon and Aluminium trim packs, RSE, PS2. Jobs done so far; Fitted an RS Steering Wheel, Fitted 15mm wheel spacers, Lowered 10mm with VCDS, Reinstalled factory DVB, Unlocked VIM, Updated MMI to 5570, Fixed Factory Bluetooth Phone, Fitted heated fan-spray washers, Installed Bluetooth DAC For Audio, Added projection Puddle lights, Wind Deflectors, Fitted Apple TV to all 3 Screens, installed car WiFi, Fitted Custom vortex Exhaust Last edited by Chip2786; 25th June 2018 at 03:55 AM. |
Thanks.
Yes cig socket is on all the time, but battery seems to cope OK. I would unplug if I was parked at the airport etc... but car is used at least 5 times a week. I will make a switched supply one day as per the video on dognmonkey.com website. I might try one of those isolators but in theory, they should reduce the audio quality a bit. I'll post back if/when i do. Last edited by snapdragon; 25th June 2018 at 09:18 AM. |
Not sure why they ran the constant all the way through the car though
I bought 2 of the ones listed above and it makes a MASSIVE difference, no loss of signal quality but when the music is paused now I hear nothing! Sounds so frikken good now! Highly recommend
I got bored of the Fire TV so I swapped it for an Apple TV, much better airplay support and still has all my favourite apps.
Instead of getting a (big nasty) power inverter I opened the Apple TV up and found that the Transformer outputs 3.3v so I bought a 12-4v in-line step down tranny and it runs it fine. Now I get the Album/Track/Art Show on my MMI screen whilst airplaying
