Not sure what Webasto heater is in the 8 but the cab heater type i have is an Airtop 5000. You can hear the fuel pump clicking when it's running. If it's not been run for a while it can take a few fire ups for it to actually start up. There is a filter in line too somewhere i would have thought. If it had the Webasto thermostat it flashes a fault code that relates to the problem. I downloaded a load of stuff for it from Butlertechnik, service, parts, fitting instructions ect
The full name is Webasto Thermo Top C.
2006 Audi A8 3.0 TDI Quattro Sport A8 W12/S8 Brakes front and rear (385mm/335mm) Focal and JBL speakers, Helix amps S8 anti-roll bars front and rear Complete rear LED taillight Xenon fog lights All interior LED S8 rims 9x20" Stage II tune S8 Grill |
This might help along with the 8 fitting guide
my A8 has one of these fitted
are they standard and what does it do and when ?
Looking for the Holy Grail Audi .. 2018 VW Caravelle Executive T6 2010 A6-C6 3.0tdi LeMans Quattro |
Also possible to get a timer unit from Webasto and a 7 day programmable type too i think
IIRC most if not all D3 tdi's had an auxilary heater - meaning it runs together with engine to aid warming the coolant quicker - you can convert to parking heater by adding receiver and remote control + some coding required probably.
oh... next time i start her up i will check the tiny exhaust underneath see if i feel any heat.. mind you that might be december time as it sorn for the winter on trickle.. ![]() ![]() ![]()
