#121
Thanks for the offer
#122
No problem
Andy. Current cars: BMW i4 M-Sport Peugeot 207 (the sons) Triumph Daytona 675 (2017 reg) =========================== Gone but not forgotten Ford Focus ST-2 Mk3 (the wifes) (stolen Oct 2023) 1972 T2 Bay Window Camper (Slow) Audi TT Mk1 225 - now with coil-overs and a 7inch touchscreen infotainment centre 2003 A8 Sport 4.2 (with ACC & LPG) (Feed up with all the issues so passed it on to a forum member) 2000 A8 FL QS 4.2 (with RNS-E - Nice ![]() |
#123
Well I figured since the printer was fubar I had nothing to lose by trying Klipper. Unbelievably it actually made the stuttering worse
![]() I need to try and find the original CR-10S firmware and put that back on. If it ain't broke, it ain't got enough features yet ![]() Also, Octoprint sounds like a good idea but isn't, at least not with our printers. |
#124
Well riddle me this: the Octoprint developer claims that the stuttering on circles is because the USB interface is too slow. In that case, how can Cura print perfectly via USB??
I've put Marlin 1.1.7 back on using the original Creality firmware and surprise surprise its printing circles again. |
#125
Glad you got it sorted.
Sounds like the developer is talking out of his arse then! Plonker.......
#126
I get the feeling that most of these developers only sample one machine.
They probably think that soak testing is printing a couple of items on one physical printer. I believe that proper testing can only be done using several different printers of each model. Of course this is expensive because for example in our case we would need three or four CR10s in the same environment to prove whatever project we are playing with. Sorry, I am being a pedantic pessimist again. And I have no idea what any of that load of W£$"£% means. ![]()
#127
Bah! Its not sorted. The firmware I found was not the actual Creality firmware, but something reverse-engineered by someone to what they think it should be
![]() ![]() Ray, Andy - how comfortable are you guys with running command line stuff to extract the firmware from your printer? I've found a utility to do it and tried it on mine. It will extract the actual Creality firmware which works (1.1.6 or 1.1.7 not sure) to a file so I can re-flash it on to mine. |
#128
Hi MJ,
I'm overnighting in Chepstow, meeting tomorrow but will be late home. Blackpool Thursday and working Friday PM. I've forwarded your request to son Craig and with luck we might be able to sort something over the weekend. After weeks of virtually nothing suddenly rushed off our feet.
#129
MJ - no problem.
Send me what you need and I will give it a go.
#130
Still want this doing?
