Old 8th June 2019, 02:18 PM
Johnmed's Avatar
Johnmed Johnmed is offline
Nice work. Are the airbags both of the same type? I know some are single stage etc.
I replaced my wheel and airbag with an S8’s, gaining paddles.
2007 Mini Cooper S R56
Old 8th June 2019, 02:30 PM
Chip2786 Chip2786 is offline
They are both dual stage airbags so no error codes on the dash
Jobs done so far;
Fitted an RS Steering Wheel, Fitted 15mm wheel spacers, Lowered 10mm with VCDS, Reinstalled factory DVB, Unlocked VIM, Updated MMI to 5570, Fixed Factory Bluetooth Phone, Fitted heated fan-spray washers, Installed Bluetooth DAC For Audio, Added projection Puddle lights, Wind Deflectors, Fitted Apple TV to all 3 Screens, installed car WiFi, Fitted Custom vortex Exhaust
Johnmed's Avatar
Happy days.
Old 8th June 2019, 03:05 PM
homer simpson's Avatar
I like that very much! What year RS3 wheel fits the D3? I wonder if there was a heated version.
Old 8th June 2019, 03:24 PM
I didn’t go by year in the end (it’s a minefield) I just bought a wheel that had the same spec as my original (flappy paddle, volume, mode button, voice assist etc) there are a lot of newer wheels that have more buttons but I’d avoid as they will be wired differently
Jobs done so far;
Old 8th June 2019, 06:03 PM
Norretal's Avatar
Norretal Norretal is offline
Nice work Chip, your mods are inspiring me
Audi TT - 2015 - Ultra
Old 10th June 2019, 07:50 AM
Its all a data bus for the multifunction wheels. Paddles, heating control, illumination and buttons all travel down a single data bus usually.
Only the horn and airbag have dedicated wires in the slip ring from memory. Heated wheels have a pair of heavy duty brushes around the slip ring to conduct the current.
I don't know what protocols are used between the later cars though, so if that's changed, it could be game over, but I suspect wiring will be surprisingly similar.
Old 10th June 2019, 07:46 AM
As far as i'm aware, there are no heated flat bottom wheels....
Every brochure, even for modern cars, you can opt for flat bottom _or_ heated but never both.....
Old 10th June 2019, 02:02 PM
Damn! I remember looking through the D3 brochure and there were certain options that were not available in sport (S8) spec like heated steering wheel and massage seats. Why Audi, why??
Old 10th June 2019, 05:24 PM
IT D3 IT D3 is offline
Well done I changed my steering from a 4 spoke to the same one you removed.
I did a bit of research too and as you say it's a minefield.
my car didn't have the flappy paddles but literally within 5 mins of playing in VCDS they were activated. Works perfectly now.
Anyway back on topic that looks great!
