D2 - Lights Headlights, xenons, foglights. Everything outside the car that glows |
looks like you have to detach the front glass , then the reflector ...not sure I have the nerve to try it though! at a guess our sponsors sell the headlight units complete with this part if unbroken Last edited by oldnick; 24th November 2019 at 05:17 PM. |
Yup, generic part, Bosch 0307853304: https://www.onlinecarparts.co.uk/bosch-666857.html
Certainly looks very similar to the unit I swapped on my Ford Focus....
Probably easier to just replace the complete headlight unit than pull one to bits. I know Prestige just dismantled a couple of A8s.
Or replace the MoT tester. I've never seen the headlamp level even tested, let alone failed on one. |
oh dear , can't see how I can change this part without breaking the assembly so have followed mikki jayne's advice [ thanks mj et al ] and sourced a headlight from our sponsors
well, I got out and got under and the problem is the circular dipped beam light which has a peculiar connector at the back , just a wire bracket or similar
any idea what exactly this is ? If it's the bit I think you're referring to it holds the bulb in place, sort of presses in and to the side then out with the bulb. What age is the D2? the early type has a glass lens and they come off in about 8 seconds from the front. Also you need to find an MOT tester that's not such a jobs worth. That's not a fail, that's a little "get that sorted for next year mate"
1996 A8 4.2 QS. Bose, Solar roof, um...um... rally sport towbar. Now gone to a new home as the Traders 8. Bright yellow bus o love. Last edited by Dezzy; 25th November 2019 at 12:52 PM. |
well job done
real faff , one of the 2 screws behind the bottom trim was rusted in solid [ after only 20 years ! ] and had to be drilled out ; waiting for it to get dark to be able to adjust the headlight manually , the electric adjustment works ok do all D2's have this electric adjustment or only the cars with factory fitted towballs I wonder ? |
