Old 9th June 2020, 08:49 AM
Not sure I can find it or even know where it is I'm afraid.
That thread you found describes in the subsequent posts how to take it apart pretty comprehensively though. Those bus bars just pry out and everything else is just clipped together so can be released undamaged with care. The PCB is quite small so not many connections to fix. And it can probably be done still mounted if you prefer to only remove the busbars.
IIRC the switch itself, although I did take it apart, wasn't my problem and can be checked externally with a multimeter so probably best to leave that in one piece.
