Old 14th November 2010, 08:05 PM
B@fink B@fink is offline
but remember folks...aftermarket HID is for show use only. I'm fed up of being blinded by dodgy HID's bolted onto a large selection of chav'd up wonders around my area. To be legal HID's need headlamp washers and auto levelling, of course, no one on here would ever consider running HID's pointing at pluto.
Old 14th November 2010, 08:28 PM
They are needed in the PF D2 though.. those lights sucked.
Another method of fitting the ballasts is to take the headlights out and you can reach down to the same brace Mike used above and cable tie them on (that's how I did it).
Old 15th November 2010, 08:38 PM
darrenjoe90's Avatar
mike can you have front fogs on with dipped beam on the pf ? sometimes i drive with dipped beam and hid fogs as it give very good light on dark roads without blinding oncoming traffic
Audi S8 Phantom Black
Old 16th November 2010, 06:24 PM
Night Train's Avatar
Yes you can Darren, my PF fog lamps are able to be turned on at the same time as the headlamp dip or main.
HTH
I'd agree that the standard lighting needs upgrading, previously on other vehicles, I've fitted the likes of H4 130/90w's, which have considerably improved visibility, especially on the 'bike, but am in a bit of a quandry with my S8, as they're wierdo modern fittings and I so far haven't found any suitable replacements at sensible money....... any suggestions?
Also..... Mike, I like the sidelights you have fitted, are they the 15 led ones?
regards,
Richard.
Other vehicles
Oh Yes....... The '98 PF S8!
Old 16th November 2010, 07:15 PM
Yes they are; and they don't cause bulb faults on the DIS.
Old 17th November 2010, 12:28 PM
Brilliant - literally
Thanks again Mike...
Other vehicles
Old 17th November 2010, 01:12 PM
Technically, legally and morally correct! But then the best things in life are either illigal, immoral or fattening.
A well set up aftermarket HID does more good than harm. I can see far better at night with them.
Washers only work when used and you have to stop and get out of the car to see if thay have been effective. Self leveling only works when you are 'not level' for more than a few seconds. So the bump/pothole will momentarily blind the oncoming driver no matter how good the self leveling system. Of course if you fill the back of your car with lead from the church roof and put the three well built thugs who helped you remove it in the back you should (morally) adjust your headlights before making your getaway!
Old 17th November 2010, 06:13 PM
which is the best kind of correct
Old 9th December 2010, 03:11 PM
Hi Mike, I fitted a pair of the LED sidelights, they really do make a difference to the front end aesthetics, they stand out more than my dip, fog or main beams which now look decidedly yellow when lit up......
Damn it, I'm just going to have to convert the dip beams to HID, I've seen a 55w (rather than the 35w) 6000k kit with 'digital' ballasts from HID's4You... any comments?
Thanks...
Other vehicles
Old 10th December 2010, 12:38 PM
Those would do nicely. You can get cheaper from e-bay, but the warranty is probably not so good.
Tags
fit
