blimey never seen a coolant line like that before, what causes that?
Just age I think. Its getting to be an increasingly common problem.
Is it possible to change that particular line whilst the engine is still in the car?
Audi S8 D2 2002 88k mls Ebony pearl effect black. Grey interior. |
Might be possible, but very difficult. It might be necessary to go in from the wheel arch. The water pipe which runs along the side of the head has to come off to get the hose out, and thats very tricky with the engine in.
Started stripping the engine today. The knock sensors are so disintegrated that half the plug stayed in the socket. The exhaust manifold bolts were just rusty stumps so an F125 would not have been fun on this one! I hammered an 11mm socket on to them and just snapped them off since they'll be replaced anyway. On to the starter motor - the braided cable from the solenoid to the motor is normally covered in silicone sleeve, but this is completely burned off! Mark mentioned that the car once failed to start and emitted some smoke from the driver's side wheel well. I had thought that was the starter junction, but thats still intact so it must have been this cable overheating for some reason The silicone has just crumbled away - never seen this before Never seen this before either! ![]() ![]() Little bits of the starter in the bellhousing A fair few chunks knocked out of the flywheel teeth too There they are stuck to the speed sensor The bank 2 exhaust manifold did a wee on the floor. The SAI valve on this side was also full of water. This unfortunately suggests a cracked head ![]() Engine on the stand Noticed this little time-bomb after taking the timing gear off - this pin is quite loose and eventually would have fallen off and in to the timing belt! Really it needs some blue loctite like all the other bolts inside the timing covers I dropped the sump with the engine the right way up, rather than flipping it over, since I didn't want any of this gunge to drain in to the engine any more than it already had. Short day today because of the F1 and family stuff. I'll dismantle the rest tomorrow, including the exhaust manifolds and upper sump and then make a start on pressure testing. |
blimey trust a car of mine to fail in new and unseen ways
I'm really not sure if i should feel unlucky.............
or lucky that none of the things you've found so far killed anything ![]() |
I can't fathom how it happened in the first place, let along how it didn't take anything much larger out with it. Possibly it was dropped when the gearbox was changed, but based on the exhaust manifold bolts that must have been well over a decade ago. Possibly a crack started which very slowly propagated until the day it failed completely? The water from the exhaust manifold is somewhat less lucky though. |
![]() The swelling around the middle, that's partly Covid related rather than age! ![]() Back to the car though... is there anything in the service history to suggest these problems? I service mine fairly regularly even though I don't do many miles.
Cars... '93 Audi Coupe 2.0 Alpine White (sold) '99 Audi S4 Merlin Purple - K04 upgrade to 412hp (sold) '00 Audi S8 Agate Grey (Sold ![]() '11 Audi Q7 4.2tdi Unknown Red (Classic Red Pearl Effect - thanks MJ) |
