Old 8th May 2021, 07:44 PM
A slightly delayed update from Monday as I needed to talk to Mark about what I found before posting it, and then I was ill for the rest of the week
The engine has been steam cleaned on the inside! It turns out this mayonnaise is quite a good detergent.
The cam bearing journals are still perfect so no bearing damage
At this point I built a pressure testing rig which was derived from my radiator pressure tester. I hooked up a header tank and either looped or blocked off the various water pipes, vacuum filled it, and then pressurised it to 1 bar.
This was the result There is a crack in #7 exhaust port.
The water pools up in the port when the valves are shut, and drips out of the inlet manifold
When the valves open it pours in to the cylinder and sits on top of the piston
The water in the sump is from the water seeping past the piston rings
So, the left (bank 2) cylinder head is toast, and used heads are pretty much unobtanium. It might be possible to find the crack and weld it, but it would be contaminated with water and soot so welding would be extremely difficult, and not economically viable. Having discussed with Mark we decided the best way ahead is a replacement engine.
ID:	26331   Click image for larger version
ID:	26332   Click image for larger version
ID:	26333   Click image for larger version
ID:	26334   Click image for larger version
ID:	26335   Click image for larger version
ID:	26336   Click image for larger version
Old 8th May 2021, 08:16 PM
Having made a shopping list and ordered a bunch of parts, I wanted a better look at the broken engine to see if it is saveable, should a head turn up in the future. Also, we wanted to see if the cam chain tensioners were still good, as I know the ones on the replacement engine are not.
Bank 2 tensioner removed - this crud in the oilway is what destroys the filter gauze which then kills the tensioner. I've never seen this much before though. I think this is gunge from the mayonnaise detergent effect cleaning everything out
Amazingly the gauze has survived!
Alas the bank 1 gauze and consequently tensioner has not survived. No idea why its always bank 1 that goes first.
The start pin still locks, but the non-return valve doesn't close fully so this will make a very brief rattle on startup, but not frightening clatter that the start pin causes.
The creamy slime drips out of every oil way
Well, you can tell which cylinder was ingesting water Its spotless!
The head has been cleaned too
The cylinder wall is perfect though - I feared the water may have washed any lubrication off the bore and caused it to be scored by the rings but it has survived, meaning the engine is definitely saveable in the future
A slight stain on the cylinder wall from where the water has been dripping in, but there's no damage to the surface. Its just discolouration.
I started stripping the engine to clean it up. I want to get as much of the emulsion out as possible before storing it so it doesn't end up separating and leaving the engine full of moisture.
Not too bad under the valley cover
The oil retention valves are pretty nasty though. I don't want to retain any of this!
The upper sump is pretty dirty too - all the usual carbon deposits have been loosened up
Very clean in the block though - all the carbon deposits have been washed off in to the sump. Just lots of the emulsion hanging about.
Cleaned with carb cleaner. Once I've got as much slime out as I can I will spray the inside with oil to keep it clean until I find a head for it.
I tipped the engine on its side with the remaining head down, with the cams removed, so the gunge can drip out under gravity overnight.
ID:	26338   Click image for larger version
ID:	26339   Click image for larger version
ID:	26340   Click image for larger version
ID:	26341   Click image for larger version
ID:	26342   Click image for larger version
ID:	26343   Click image for larger version
ID:	26344   Click image for larger version
ID:	26345   Click image for larger version
ID:	26346   Click image for larger version
ID:	26348   Click image for larger version
ID:	26349   Click image for larger version
ID:	26350   Click image for larger version
ID:	26351   Click image for larger version
ID:	26352   Click image for larger version
ID:	26353   Click image for larger version
ID:	26354   Click image for larger version
ID:	26355   Click image for larger version
ID:	26356   Click image for larger version
Old 8th May 2021, 09:43 PM
Markiii Markiii is offline
looks surprisingly good in there all things considered.
makes me wonder if a steam clean isn't a good idea
Old 8th May 2021, 09:51 PM
These heads of no use?
https://www.ebay.co.uk/itm/GENUINE-A....m46890.l49286
Audi S8 D2 2002 88k mls
Old 8th May 2021, 10:08 PM
They might work, but I'm suspicious why there are no cam chains on them and why the tensioners appear to have been removed. They may well be an equal can of worms, and tbh after shipping and gaskets etc its about even to just get a known-good replacement engine.
Old 9th May 2021, 08:42 AM
Ronin Ronin is offline
Smile
I'm sooooo glad I removed my tensioner filters now even though I change the oil every 5k
Old 9th May 2021, 09:03 AM
so is removing them a good idea?
Old 9th May 2021, 09:39 AM
Yes, I take them out now, on the basis that its less bad to have that gunge go through the tensioner than stainless steel mesh.
Old 19th May 2021, 08:11 PM
A tad behind with updates on this sorry. Its taken a little while to work out what to do engine-wise. In the meantime, I tidied up the broken one, since it would go back together when a head turned up.
I cleaned up the block ready to put the lower sump back on
For those who may be curious, this is where the crank locking pin goes.
Lower sump back on
Metal oil cooler pipe
I flushed the oil cooler with brake cleaner until no more slime came out, then put it back on
Cleaned up the mounting face on the block ready for when a head turns up
I'd removed the oil retention valves while the engine was upside down to let the slime drain out. Cleaned them up and put them back in.
The breather plate is a; really expensive and b; back-ordered so I cleaned it and re-sealed it using the same silicone as used on the sump.
Ready for a replacement head.
ID:	26405   Click image for larger version
ID:	26406   Click image for larger version
ID:	26407   Click image for larger version
ID:	26408   Click image for larger version
ID:	26409   Click image for larger version
ID:	26410   Click image for larger version
ID:	26411   Click image for larger version
ID:	26412   Click image for larger version
ID:	26413   Click image for larger version
Old 19th May 2021, 08:27 PM
Having failed to find a head, I acquired a replacement engine. Of course, as soon as the engine was on a pallet heading Southwest, I also found a head So now I have a spare engine (yay) and Mark's engine is going back together and back in the car
I put the cams and tensioner back in the good head
New oil seals
This head all done
This is the replacement head. The inlet valves are fine, but the exhaust valves are leaking slightly so they'll need to be lapped in. This bar is the roller which the rocker arms sit on.
The rockers need to come out to get easy access to the valves
The exhaust valve seats are a little crusty
This is why the head was taken off - the other side suffered a timing incident and exploded. This side ate a small bit of debris and just dinged the head slightly but its still perfectly usable.
Crusty valves too
Much better
2 done, 6 to go
ID:	26415   Click image for larger version
ID:	26416   Click image for larger version
ID:	26417   Click image for larger version
ID:	26418   Click image for larger version
ID:	26419   Click image for larger version
ID:	26420   Click image for larger version
ID:	26421   Click image for larger version
ID:	26422   Click image for larger version
ID:	26423   Click image for larger version
ID:	26425   Click image for larger version
