![]() Though personally I'd probably avoid using that input unless you're doing a full OEM install - you just never know how the various controllers interact so KISS. I also note from that thread Sean took power from the sunroof (as I did on my PF) and similarly just found a good earth point.
2003 D2 FL S8. Irish Green Pearl/Beige. Solar sunroof, auto-dim mirrors, electric rear seat functions and extended leather. Ski hatch retrofit. Aftermarket reversing camera. DVB-T and XCarlink now removed as redundant. 2016 Volvo V40 T5 Cross Country (4WD) with ALL the toys including adaptive cruise etc. etc. Osmium Grey with Blonde/Charcoal leather interior. Polestar performance "optimisation". ![]() ![]() Finally: gone, but not forgotten..... 1998 D2 PF S8. Agate Grey/Platinum. Every option (I think) except electric rear seats, Tiptronic steering wheel, ski hatch, towbar & dimming door mirrors. e.g. Cruise control, NavPlus/TV, Bose, GSM, Xenons, Solar roof, Parking sensors, Alcantara/leather everywhere of course. ![]() 1998 (very early) Ford Focus 1.8 Zetec; ABS/TCS, Heated screen/mirrors, Aircon. Added Auto-dim mirror, Leather seats, Trip computer, Cruise control, OEM Ford SatNav with CD changer. And before that a lot of Rover 800s, a few oddities, a lovely Triumph Dolomite 1850HL with Overdrive and way back in my schooldays an Austin Seven aka Mini 850! Last edited by HPsauce; 8th July 2021 at 10:22 AM. |
So I've been studying the wiring diagram for the interior lights and think I have the solution.
The usual plug on the mirror with/without dimming has the pins below: 1. Red - Always live even when ignition off. 2. Grey/Green - Switched live with headlights. Also same colour wire provides power to other lights (e.g. ashtray) 3. Green - Unsure. Some reversible ground from lights? Goran indicates this as being activated by driver's reading light switch but then connected it to the negative for the Dashcam. 4. Grey - Not sure but possibly related to headlights or perhaps the other reading light, only other grey I can see is between the headlight switch and the relay in the footwell. 5. Blue - Ground. Another blue on the tiptronic switch is connected to ground (brown) so seems logical this does too. So I found a 9v battery and connected the positive to pin 2 and negative to pin 5 and the red ambient lights switched on. I think this is where I need to connect pins 2 and 1 from the dimming circuit. Not sure if I can connect pin 3 from the mirror (linked to reading light switching) to pin 6 of the dimming (normally connected to interior front and reading lights) any thoughts?!
Cars... '93 Audi Coupe 2.0 Alpine White (sold) '99 Audi S4 Merlin Purple - K04 upgrade to 412hp (sold) '00 Audi S8 Agate Grey (Sold ![]() '11 Audi Q7 4.2tdi Unknown Red (Classic Red Pearl Effect - thanks MJ) Last edited by pete-p; 9th July 2021 at 10:49 AM. |
The next thing I need to work out is how does the mirror come out and go back in?
Cars... '93 Audi Coupe 2.0 Alpine White (sold) '99 Audi S4 Merlin Purple - K04 upgrade to 412hp (sold) '00 Audi S8 Agate Grey (Sold ![]() '11 Audi Q7 4.2tdi Unknown Red (Classic Red Pearl Effect - thanks MJ) |
That's the least fun part of the whole process - it is held in with sprung pins and needs a silly amount of force to get it out. The manual shows an angle to pull it from iirc, and it comes out with quite a pop.
Thanks MJ.
That was remarkably easy, only a little fiddly putting the new mirror back in.
I'm glad I soldered the wires between the two mirror looms, there really isn't much space and scotchblocks may not have fitted through! I didn't connect anything from the interior lighting so just the power from the ambient lighting in the mirror. All works as expected and I didn't notice the interior lights causing any issues. I think it makes the interior just that little bit tidier and more modern. ![]()
