Old 21st September 2021, 03:44 PM
PF doesn't have a switch for PDC since it only works on the rear so engages and disengages with reverse gear.
Old 21st September 2021, 04:40 PM
Assuming it is the same as the B6/B7 A4, I can vouch for that cup holder being nearly useless for holding cups, and the biggest issue is that if (or when) something spills it is not a great position for the escaping liquid!
That said, it would "fill up" three blanks if you can make it work
Old 21st September 2021, 04:51 PM
1. Swap "P" with "ESP" button.
2. Move "ESP" button under the steering wheel
( there is a pre-facelift "ESP" button https://www.ebay.co.uk/itm/133666627121 -- just make sure you get electric connector for it too )
Both operations will requite extending electric harness a bit, but entirely possible.
Old 21st September 2021, 05:14 PM
That makes a lot more sense, when did you last use the ESP button?
I know the last time it was used on my PF S8; it was when the scum that stole it decided to find out what it was for and the car ended up in a hedge!
Old 21st September 2021, 06:41 PM
I will stand correcting - but I believe the blank (and headlamp leveller switch where xenons not fitted) are slightly curved to match the dashboard....
I'm not sure there are any switches that will fit that gap as all the PF switches are flat as you 'd expect on a dashboard....
Old 21st September 2021, 06:49 PM
Please stand Ian and take your corrective punishment.
Just been to check mine and it's a perfect fit.
Old 21st September 2021, 06:58 PM
Well, almost, more than good enough unless you're looking extremely closely.
