Old 17th May 2022, 08:25 PM
I prefer daily driving the Allroad to Big Red simply because of the gearbox. The auto ruins the 2.8 for me because it is so stupidly programmed. I'm not planning on taking a 5HP round Spa
Not much to report on the thread this evening. I put the oil back in the gearbox and put the gearbox back on the separating machine. Its going to spend overnight with two bellhousing bolts in and the valve body connector connected and make sure there are no more leaks before I reattach the converter and starter etc etc.
I pulled the power steering pipes off as they're pretty crusty. Hopefully I can get those off to the hydraulic shop tomorrow.
Old 21st May 2022, 08:18 PM
A good day today I put the engine and gearbox back on the subframe, but forgot to get any pics of that, then moved on to cleaning
First pass of APC
Sprayed with tar remover
Rinsed down after a second pass with APC
Nice and clean
The other side was much the same
Botang's hole needed attention, and since the interior is already out its pretty simple to take the electronics box out, and looking under here its a good job that I did! At some point in its life the water has got pretty high in here
Botang's hole just hiding there under the AC pipe
The source of the rust stains I've never seen one in this state, and tbh this is classified as 'nicht gerfingerpoken'. There are no more of these, and this is miraculously still working so I shall leave it alone. We can put it on the list for replacement when I reinvent this whole heater block
Hoovered out and there is an orange tide mark about 2" up
I attacked it with Bilt Hamber Auto-wheel, which is a first for me in this area! It immediately got to work on the iron and turned a deep purple.
Much better
The blower motor is getting replaced with a D3 version which is made considerably easier with the ecu box out as well
The D3 motor has a different connector
D2 connector spliced on to the D3 blower
Wrapped up
ID:	28497   Click image for larger version
ID:	28498   Click image for larger version
ID:	28499   Click image for larger version
ID:	28500   Click image for larger version
ID:	28501   Click image for larger version
ID:	28502   Click image for larger version
ID:	28503   Click image for larger version
ID:	28504   Click image for larger version
ID:	28505   Click image for larger version
ID:	28507   Click image for larger version
ID:	28508   Click image for larger version
ID:	28509   Click image for larger version
ID:	28510   Click image for larger version
ID:	28511   Click image for larger version
ID:	28512   Click image for larger version
ID:	28513   Click image for larger version
Old 21st May 2022, 08:26 PM
I've had some horrendous problems with the scuttle drains, the evidence is exposed above!
What exactly is the very rusty component that is "nicht gerfingerpoken" and is NLA but you're thinking of a solution to?
And what happens when it goes wrong?
I like your thinking.
Presumably all a bit more comfortable to work on with no bonnet?
Old 21st May 2022, 08:37 PM
Very pleasant working with no bonnet That may become standard procedure.
The rusty lump is the water pump for the heater. Its built in to the side of the heater valve block and is supposed to push coolant through the two heater cores as the engine water pump doesn't have enough flow or pressure to get through the valve block. When the pump fails it just takes a while for the heater to heat up.
Good working valve blocks with good working motors are unobtanium now so I plan to redesign it using parts from the C7 A6 which has separate valves and pump. They're newer, cheaper and smaller. It's just going to need some creative plumbing to stick it in the space where the D2 valve block goes.
The drains are all clear now
Old 21st May 2022, 08:39 PM
So not the "Auxiliary coolant pump" that gets noisy as it ages? The one that kicks in when you use the "Rest" function.
If it is I've cut the wiring to it and taped it up as it got really noisy years ago (just like my original PF S8).
Heater still warms up fast enough for me.
Old 21st May 2022, 08:43 PM
Yes it's that. I guess thats why its not making a noise then
Old 21st May 2022, 08:45 PM
Good to know. If you have a rummage around you should find the cut wires taped up with Certoflex.
Looking at this was IIRC item 27 on my list from early March, I think you commented then about a future solution with A6 components, potential retrofit as definitely not ready in time.
Old 23rd May 2022, 10:58 AM
pete-p's Avatar
pete-p pete-p is offline
What's the benefit of using the D3 version? Is it that the D2 is nla or is the D3 version better and quieter?
Cars...
Old 23rd May 2022, 11:05 AM
Ronin Ronin is offline
It's the same part with different connector that has reversed polarity. D2 part is NLA.
Old 23rd May 2022, 05:33 PM
johnny_quattro's Avatar
I learn something new every day on this forum and long may that continue.
John G
