The trim is on with the clips, then retained properly with the screws.. Pretty sure mine had at least 3 screws in it.
I can't see any other holes from the inside.....
Just an update - went to look at the clips the local dealer ordered in for me - they're the blue ones I can see part of hiding behind the remains of the trim still attached to the car
![]() Have now had to order a complete new trim (about 70 quid) which does, thankfully, at least come with the half dozen trim clips. It looks like the remains of the outer trim have been stuck back on rather poorly in the past, so what I've removed is only the very outer layer of the trim - I still have to remove the rest, which I am told slides across like the inner trim cover to get it off the clips. I'm not going to remove the rest till Saturday as (a) I'll have the new one to compare to by then (b) the weather strip is still sealing the door bottom so it's better off where it is, even though it looks a mess..... |
useful thread. added to Sticky; Thank you Adrian.
hmm, subtley different take on this. My bottom door trim appears to be one piece. Removal required the extraction of two bungs either end of the inside of the door. removal of two little screws revealed and slide the whole exterior trim away from the hinge end and then off. Clips secure to trim then clips (with trim attached) slide over corresponding little posts on door panel.
"Man Math" - The means by which a caring husband convinces his wife that a 4.2 A8 is in fact cheaper to run than a tiny Auto crap box "Being in touch with your feminine side" - The ability to, in the 30 seconds following a major accident, obtain your wifes approval for replacing your big german car with another "because otherwise we'd be dead". See also sulking for two years until she finally allows you to get another purely on the basis of your current one being the wrong colour. |
Yeah, that's how it should be - mine had been bodged in the past with a glue gun!
Never took pics in the end of this, because the day after buying the trim my mirrors got stolen so the swapping of the trim got done by the bodyshop while they had it in to repair.... ![]() |
Digging up an old thread...
I need the driver and passenger front door lower mouldings - can anyone confirm the part numbers I need are: 4D0 854 939 A 3FZ 4D0 854 940 A 3FZ Dropped off the car at the garage for the cambelt - whilst there got him to provide a quote, both of these are 164 + vat each ![]() |
Old thread resurrection!
![]() My drivers door lower trim is damaged; while doing some pre-MJ checks I caught my leg on it a few weeks ago! She didn't have time, given the huge load of other jobs, to look at it while it was there. I found the plastic strip on the inside but it didn't want to slide. ![]() It was quite loose at one end anyway and eventually just unclipped straight off; hopefully not too damaged to clip back on, otherwise it may need some adhesive or double-sided tape at the end of the job. This is the door trim, not bad but I know it's wrong:
![]() Fortunately there's not much damage and I can probably ease the plastic channel back into it's proper shape and slide it back on securely in due course. ![]() Part of it had quite a bit of dirt behind, where it hadn't been fixed fully flush against the door surface. ![]()
2003 D2 FL S8. Irish Green Pearl/Beige. Solar sunroof, auto-dim mirrors, electric rear seat functions and extended leather. Ski hatch retrofit. Aftermarket reversing camera. DVB-T and XCarlink now removed as redundant. 2016 Volvo V40 T5 Cross Country (4WD) with ALL the toys including adaptive cruise etc. etc. Osmium Grey with Blonde/Charcoal leather interior. Polestar performance "optimisation". ![]() ![]() Finally: gone, but not forgotten..... 1998 D2 PF S8. Agate Grey/Platinum. Every option (I think) except electric rear seats, Tiptronic steering wheel, ski hatch, towbar & dimming door mirrors. e.g. Cruise control, NavPlus/TV, Bose, GSM, Xenons, Solar roof, Parking sensors, Alcantara/leather everywhere of course. ![]() 1998 (very early) Ford Focus 1.8 Zetec; ABS/TCS, Heated screen/mirrors, Aircon. Added Auto-dim mirror, Leather seats, Trip computer, Cruise control, OEM Ford SatNav with CD changer. And before that a lot of Rover 800s, a few oddities, a lovely Triumph Dolomite 1850HL with Overdrive and way back in my schooldays an Austin Seven aka Mini 850! Last edited by HPsauce; 1st July 2022 at 11:06 AM. |
