Guys,
Probably just being thick here.. But when replacing the D3 pads and putting the new thickness into VCDS, what thickness to I use, the width of 1 pad, or both together?
If you cycle the handbrake (as you should do) you shouldn't need to enter a value. But the thickness is of 1 pad.
07 Silver D3 A/S8L Quattro ![]() ![]() |
Ty Bex.. Thought it was.
Sorry to drag up an old thread but better this than starting a new one on the same subject.
When putting in the pad thickness am I correct in thinking it is the thickness of the Ferodo material that is entered and not the material and the metal backing |
It is
