Old 1st December 2011, 11:21 AM
PM received, payment made. Thanks.
Old 2nd December 2011, 12:59 PM
Frosty morning, checked the mirrors, neither defrost/demist now.
Time to RTFM; checked the fuse which is fine.
The manual says they're on when the ignition is on, that's it.
No temperature trigger at all - can anyone confirm that?
When the replacement arrives and is fitted I'll know more.....
Old 2nd December 2011, 01:29 PM
I think they come on together with rear window heater
Old 2nd December 2011, 01:39 PM
I tried that just in case as it was an obvious possibility; no difference.
The manual makes no connection between them that I saw.
Old 2nd December 2011, 05:09 PM
My A8 manual says they come on together with rear window heater, A6 that they come on depending on outside temperature
Old 2nd December 2011, 11:29 PM
In a lot of Audis you also have to have the mirror adjust button turned to centre rather than left or right mirror otherwise they wont heat when the rear screen heater is on either
Old 3rd December 2011, 08:31 AM
That's a bit devious!
Mines almost permanently on left (for the reverse dip), so I'll try that.
Not today though, 10C here already!
