'morning all - just had a go at investigating this further - with little luck. Unable to get my trolley jack under the car when it's in the garage (not enough room under the car) so had to place one corner on the kerb to be able to jack it up and remove the wheel - which then forces the system to disable itself (all options greyed out), making troubleshooting somewhat impossible!
I've managed to narrow it down to the front right corner (LHD car) but can't figure out a way to get access with the system activated to look further. Compressor is definitely still going and the only faults recurring are the leak in system and lower limit exceeded.
Any suggestions before I am forced to take her to the stealers?
Cheers.
