Old 19th January 2012, 05:32 AM
So just change coding and you will see if it is because of coding or something else. It's less then 5min job that can be done with the £8 e-bay cable.
Codings are automatic:
with ESP 03373
without ESP 03273
and manual:
with ESP 03313
without ESP 03213
First digits may be 04 on later cars for MVEG II emissions standard
Old 19th January 2012, 12:16 PM
Nollywood's Avatar
^^^ Thanks bud.
Old 19th January 2012, 07:43 PM
71camaro 71camaro is offline
On Quattroworld, to view a complete thread click "all messages." It's located at the top left of the reply you're reading.
Old 19th January 2012, 07:59 PM
Nollywood's Avatar
Thanks bud, that's a great help, will go there now.
Old 23rd January 2012, 12:50 PM
A8 Doc A8 Doc is offline
Sounds a cool conversion.
If you're codes dont match above, post up the codes in your engine controller and we can have a go.
Old 23rd January 2012, 05:20 PM
Nollywood's Avatar
Thanks Doc.
Old 10th March 2014, 08:53 PM
le cric le cric is offline
digging up an old thread here but i need some help!
ive just got an AHC ecu and ive tried coding it with vagcom but it will not save when i code it to manual. i can change the from 2wd-4wd and it'll save, but no luck between auto and manual.
Im wondering if i need a login code and where to get one!
current code is 04373 and i want 04213.
Thanks in advance
