Well guy's, i got some good news for those of you with "original" Webasto Thermo Top Z/C heaters with fried controllers. The aftermarket boards work like a charm!
![]() This is how it all looks like: ![]() ![]() ![]() ![]() |
Hi, did fit this controller to facelift? I have the same problem with fried board. But not sure is will work with A/C and webasto remote controler?
Yeah it works like it should now. But the diagnostic thru vagcom/obd don't work since the new controller has blink code diagnostics.
Thank you. Any chance to make diagnostics in future?
No i doubt that since this is a aftermarket board. Made to substitute the universal Webasto's and not the brand specific that's in our Audi's and BMW's.
But the diagnostic's function on this board is more than good enough. Just have to unscrew the right fog light and bezel. Then remove the lid on the webasto so that you can see the board. And then just short one of the wires. (Might be that the fould codes is read be beep code, and in that case it's not needed to reomve to lid. And just listen to the sound). And another thing is that the guy i bought if from has really good communication if you have some kind of problem ![]() |
