Thank you so much!
Yes, mine is a faithfull 4 speed box, I've been keeping it for 10 years! No big issues so far, drive just right. But from some 4 years back, running idle it sounds like a diesel engine, no more that nice V8 muted purr. Asked some 4 different technicians to check it, they spent several hours checking every pulley etc and found nothing! Maybe some valve clattering, I don't know. Otherwise the car run just great. It sounds OK at any rpm above idle. Have you ever heard something like this before? Many thanks! BTW, nice MJ pic, one of my fav artists! Cheers, Doug Last edited by Doug773; 29th February 2012 at 03:11 AM. |
Welcome from me too
![]() Your gearbox code should be on your build sticker both on the car (in the spare wheel well) and on the front inside cover of your original service booklet if you have it. The gearbox code position is shown on this thread HERE
Camshaft chain tension is maintained by oil pressure in our engines AFAIK. If oil pressure is not that strong enough at idling, then chain starts to rattle. When RPM goes above idle, the oil pressure becomes strong enough to tension chain properly. Change oil pump and problem should disappear.
I'd rather drive on left |
Men have feelings too. For example we feel hungry..... |
Each bank of cylinders is driven by 2 camshafts (V8 has 4 camshafts) , the first camshaft is driven by the cambelt whereas the second camshaft is driven by a chain that connects both camshafts together inside the head.
I'm guessing it's CML, it's also on the box it's self but you'll have to get it on a ramp or similar to see.
I had my box done recently, fluid and filter. No issues...... Yet!
Right. These two chains are located on the back side of the engine. So if engine sounds diesel when idling the first thing is to chech the sound of back top side of cylinder head, not the front side where all pulles and belts are.
If these are chains, than it's almost 100% low oil pressure at idling. Warning lamp still doesn't come on, but it is enough to hear the rattling sound. Can be further diagnosed by measuring oil pressure at idling by connecting manometer. Subframe out, engine sump out, and check if oil pump is clogged with debris. If not, then change oil pump (plug and play operation).
