God work! They are extremely heavy, I've pulled the ZF from a C5 A6 3,0 quattro, and that was a nasty job too.
I had to get help to raise it onto the work bench. Luckily, all I was replacing was the torque converte, and both output shaft seals.
2006 Audi A8 D3 Quattro Sport 4.2 TDI - Silver, Family Oil Burner. 2000 Audi A4 Quattro Sport 2.5 TDI - Santorin Blue, S8-Powered DTM Race Car Build In Progress. 2000 Audi A4 Quattro Sport 2.8 30V - Pelican Blue, RS4 Widebody, D3 4.2 01E, High-Spec B5 Build In Progress. |
Looking good so far...
Very quick reply to say that we've found the culprit.
An O-ring! This has resulted in a lack of oil pressure to the A pack (1-4 gears) so it started slipping as soon as the oil warmed up. This is the reason that I was able to drive it when cold. Damage to other parts is fairly contained but will include a drum, bearing and obviously THE O-ring! I did try to get to reverse gear to have a look but after pulling everything out of the gearbox, it was obvious that this wasn't possible without pulling the transfer box, torsen diff etc off and I'm not prepared to do that as it's all working well. I'll post up photos tonight if I get a chance. MG |
Love this thread and the detail. Photos good and can't wait for more when available. Thanks
D2 FL Q 2.8 V6 2002 Taxi(?) spec - no heated seats headlight washers etc. D2 PF Q 2.5 tdi LHD rear blinds and heated rear seats, Bose, 5 speed Tip, Servotronic, Pioneer AVIC 333,333 km Murdered on a P&O ferry 2012. Cat3 write off |
Anywhooo... on with the photos. Sooo the car is on the ramp. First thing out of the way is the exhaust. We ended up cutting through the clamp bolts and some of the flange bolts. The clamps did however still slide out of the way. ![]() Yes I did start it up like this ![]() One CAT out of the way with Lambda sensor. You can get to the wiring from under the front carpets which thankfully just lift up. ![]() The downpipes are a real sod to get off. Some of the nuts are accessible from above, some from below but it took all manner of extensions, UJs etc to get to them individually. ![]() The pile of stuff removed grows... ![]() Wheels off to get to the driveshaft bolts and CV boot shields. ![]() Axle stand out of shot. It was at this point that I realised that the starter motor was going to be one of the toughest things to remove. You've got to remove this to get to the torque convertor bolts. The problem is that it sits behind the right hand engine mount. FUN! You can't remove the mount easily as there's no room. You can just see the bottom starter motor bolt in this photo. ![]() I ended up loosening the subframe, working out just how far I could drop the bolt out so that it still 3 turns of threads going into the bodyshell. With this, I managed to get the engine mount just out of the way to get to the starter motor. ![]() A little bit more jiggery pokery and I managed to get bolt the engine mount and starter motor out of the way. Now we can get to the three flex plate TO torque convertor bolts out. ![]() Here's how the starter motor and engine mount sit when bolted up. ![]() If anyone ever asks you to 'just' change the starter motor on an Audi V8... run away! More to come... MG Last edited by SyncroS8; 7th April 2012 at 08:04 PM. |
This was where it got fairly serious and the camera got left out a bit.
The list of stuff to remove... Wiring, crank sensor, oil pipes (clamp these or oil goes everywhere!), shifter rod, propshaft (we managed to leave it in situ rather than have to drop the rest of the exhaust to get to the rear bolts), drain the oil!, Trans mounts, cv joint shields, last bit of wiring to the back of the gearbox from the engine. I'm sure that there's stuff I've forgotten! We're now at the point of having the gearbox jack supporting the gearbox and trying to work out how to get the thing out! In the end, we dropped the back of the subframe down and there was enough room to get the trans out. Everything gets covered in oil as the torque convertor never separates as it should from the flex plate so you're slipping around a bit. Gearbox in the Skoda ready to home. ![]() Sooooo with the gearbox at home on the bench. It's time to start the strip down. MG Last edited by SyncroS8; 8th June 2012 at 01:16 PM. |
Firstly, this is one BIG gearbox. I think it tips the scales at around 160kg. Not the kind of gearbox you want to try and catch or have drop on your toe.
I've put my garage mug in the photo to give you an idea of the size. Please bear in mind that this is the first Auto Transmission I've ever stripped down, I don't have the manual (it's not cheap and I am!) and I'm working on 'this looks fairly obvious as to how it comes to pieces' or 'that's not good' for condition of parts. Plus the internet is a very powerful tool for this stuff. ![]() So, remove the torque convertor and you're looking at a load of torx bolts. ![]() Not forgetting the two small rubber caps at the bottom behind which are two more bolts. ![]() Once you remove these caps, it becomes obvious that the bolts are behind the flange shaft which goes into the diff. What's more, they're behind a tube inside which runs the shaft. So... out with the diff. Unbolt the flange by removing the centre bolt in the flange followed by all the bolts holding the side plate on. ![]() ![]() Be careful pulling the side plate off like this as the diff is more that likely to drop out too.. and it's rather heavy! Now, remove the three bolts which hold the bearing housing from the other side of the gearbox which are just behind the driveshaft flange. I also removed the speed sensor here just to stop it from being damaged. ![]() ![]() Pull the shaft out and there's the hole! ![]() With a circlip! ![]() Which hold the tube in place. Turn the gearbox around and give the tube a tap to get it moving and it comes out where the circlip was. ![]() It was at this point that I turned my attention back to the intermediate plate which houses the oil pump. Now you can see the bolts rather than a tube! ![]() The large of the two splines are part of the intermediate plate and I'm fairly sure that the factory puller would use this to pull on and push against the central shaft. I don't have one! I wasn't sure if the oil lines that run above the valve body actually sat into the intermediate plate or not and didn't want to chance damaging anything so the sump plate etc came off next. ![]() Valve body... Note that there are two sizes of bolts here. Some hold the lower sections of the valve body to the top sections and some hold the whole valve body onto the gearbox. The ones you want to remove have the bigger diameter heads. ![]() Wiring - this is held in place with a large circlip. ![]() With this off (forgot to take a photo, sorry) it was obvious that the pipes didn't actually go into the intermediate plate but I was able to push on the back of the intermediate plate from underneath and this allowed me to remove it without a puller! ![]() ![]() ![]() Onto the next parts... ![]() MG Last edited by SyncroS8; 7th April 2012 at 09:30 PM. |
