Old 16th April 2012, 10:14 PM
I would imagine a LHD pedal box will be shaped incorrectly to fit a RHD footwell in terms of mounting points and shape. I've not seen an '8 pedal box off the car so might be worth a look at the open day and see how likely it is that the pedal box will be fairly universal. I would imagine the LHD clutch pedal would foul the transmission tunnel. If the pedal box will fit you might be able to offset the pedals to make it fit?
Think I remember reading that an A6 pedal box could be modified to fit? There's always work arounds - it's a case of how much fabrication is required to make it work and be reliable.
Item 1 in the attached is the main part that's different, but ideally you'd want a complete pedal box I suspect
