Old 30th April 2012, 03:38 PM
barzya8 barzya8 is offline
32 PSI or 2.2 bar all round with 2 people and luggage
Hope this helps
David
Guildford, Surrey
Bose sound system.
Audi Navigation Plus.
20 inch Final Edition alloys
Old 30th April 2012, 03:42 PM
SyncroS8 SyncroS8 is offline
Thanks David,
Could someone give me the part numbers from the stickers that I should have in the filler flap so that I can order them from Audi please?
Then I won't be wondering again!
Or... a photo of them would do for now.
Thanks
MG
Old 30th April 2012, 03:46 PM
I find it varied between 34 and 38 depending on the tyres I ran, some were noisier at lower pressures.
Old 30th April 2012, 03:54 PM
Here you go, been meaning to do this for a while.
You can probably just read the range of tyre sizes too.
Old 2nd May 2012, 09:48 PM
Thanks all.
I'm running Bridgestone Potenza RE050A 245-45-18s. They're set at 32psi now. I can hear them more than I was expecting. I don't want to over inflate them and have the centre of the tread wear out prematurely.
MG
Old 9th May 2012, 08:28 AM
Me being silly... can someone check if the face lift model has the same stickers as the pre face lift as listed above please?
MG
Old 9th May 2012, 10:21 AM
MG
My 2002 S8 has the same pressures but only quotes for 245/45/R18s and 225/55/R17s. (i.e. not the 225/60/R16 as in your photo) but it has an additional sticker for 255/35/ZR20s as follows:
part loaded = 2.4/36/240 (front and rear)
Full load = 3.2/46/320 (front and rear)
See attached photo. Hope this helps.
Name:	Tyre Pressures.jpg
