Old 11th May 2009, 03:43 PM
builder22 builder22 is offline
Thanks guys,
So I’m wondering if this guy actually has 450BHP at all. He has a 2000 D2 S8 but it doesn't look like it has anything special on it but I could be wrong.
As for me I’ve "only" got a straight 4.2 and if re-mapping is only going to yield 10-15 more BHP is it hardly worth it.
Might be better to spend the money on something else.
Old 11th May 2009, 03:50 PM
For my two penneth, getting the power up on a D2 is a tricky, and more importantly expensive job...
Consider taking a leaf out of Botangs book, and getting the weight down instead...
Electric rear seats, bose, blinds, LPG tanks, Towbars, boot full of stuff, solar panels, airbags, twin pane glass - all adds weight.
For what it costs to get 10/15bhp more out of it, you could get the equivelent 'performance gain' by making it lighter..
It would be interesting to see the weight difference between a 'fully loaded' D2, and one with less spec...
Time to compare build stickers everyone ?
Old 11th May 2009, 04:00 PM
Well then I’ve got a lardy one so cos I’ve got all of those apart from the towbar and LPG tank.
Not too mention the not so slight occupant in the drivers seat, I must be worth at least 40 BHP...
Old 15th May 2009, 09:31 AM
ulfilias ulfilias is offline
Hi There,
Why more power (apart from the Tim Allen style comedy) ???
The 0-60 is pretty good, the 30-100 is awesome. The power range is great. The overtaking is already incredable - Particularly if you drop gears and do it right.
I always found this with some of my older cars that were far less powerful, its more the way you drive than the power you have.
cya,
Lee
Old 15th May 2009, 11:20 PM
More power well i suppose i was just checking. If it was going to be an "easy" fix then why not.
Based on the feedback to date i think i'll give a miss.
Old 20th June 2009, 07:08 AM
CliveH's Avatar
CliveH CliveH is offline
As stated above, you might squeeze a bit more out with a freer flowing exhaust and a remap (possibly even 20bhp) but the only way to get up to the dizzy heights of 450bhp would be supercharging/turbocharging.
Weight saving would be a more economic way to go, but would lose of lot of the 8 'charm' IMHO.
Do it right and create an RS8 by dropping a (C5) RS6 lump in there!
Present: S4 B8 avant, fully loaded, MRC Stage2, Milltek non-res, KW springs
Past: S8 D2 FL, S2 ABY coupe, RS6 C5 saloon, RS4 B7 saloon, S4 B5 saloon, S4 B6 avant, all gone but not forgotten
