Old 31st May 2012, 09:54 PM
b10nus b10nus is offline
Default A8 Center caps wanted code 4E0601025N
Hi all.
Someone was kind enough last night to relive my lovely car (D3) of its centre wheel caps. Iv phoned Audi and been quoted £130 which considering the wheels plus tyres cost me £380 on ebay is abit of a bitter pill, iv included the code in the title and i think they are the wheels that come on the W12.
Iv phoned around some breakers and checked ebay with no luck. Im wondering if anyone has a set or can point me in the right direction to get a set
Heres hoping
Old 31st May 2012, 10:06 PM
Amanda Amanda is offline
Piccie would really help?
Old 31st May 2012, 10:09 PM
47p2's Avatar
47p2 47p2 is offline
Look for a very cheap set on ebay that have lots of corrosion around the outer ring and remove the ring.
Before
After
Before
After
Nite Blue 3.0L SE Quattro
Old 31st May 2012, 10:12 PM
Thanks 47. im struggling to find ANYTHING corroded or not. Is there any other caps that would fit or is it likely that they are specific to the exact wheel. I fear the latter.
Old 31st May 2012, 10:28 PM
47p2's Avatar
Not sure there will be anything else that will fit
Old 31st May 2012, 10:45 PM
aTOMic's Avatar
aTOMic aTOMic is offline
Look for a very cheap set on ebay that have lots of corrosion around the outer ring and remove the ring...
Oooh, is that outer (corroded) part separate? I'm excited! the biggest (only) niggling eyesore on my car could be history!
Going out now to check it...
I'm in love with a car.
2004 4.2L Petrol A8L
Sage Green/Black (one of only five D3s thus colored sold in the US)
Old 31st May 2012, 10:46 PM
47p2's Avatar
Yes it comes off, bend the tabs at the back and remove the corroded ring, then clean up the cap with some cutting compound and polish
Old 31st May 2012, 10:48 PM
47p2's Avatar
The part number for the cap is 4E0 601 165 A
Dimensions are 145mm across the front and 60mm at the rear
Old 31st May 2012, 10:50 PM
47p2's Avatar
Here you go
Old 31st May 2012, 11:23 PM
Wow, top banana 47 thanks for the link. I wonder what the chances are of them being my original ones ha ha ha!
