Old 4th June 2012, 08:00 AM
Mine comes on sometimes, and again with mine its the cats playing up. A quick erase with Vag-com and it will stay off for another month or so before coming back on. If the car drives and feels fine then I would just drive it TBH.
Old 4th June 2012, 08:10 AM
Nollywood's Avatar
Just drive it, and don't stress too much. As long as you have no misfires and don't drive WOT 80% of the time, you'll be fine.
Where else would you get advice at 0900 on a BH morning!! Many thanks. If there was someone with Vagcom near then I would try to stop by if they are able tp help.
Old 4th June 2012, 08:45 AM
47p2's Avatar
47p2 47p2 is offline
...then I would try to stop...
Brake problems as well as EMS light then?
Nite Blue 3.0L SE Quattro
Old 4th June 2012, 02:00 PM
I'm in Swindon with a Vagcom cable David but its probably a bit out of your way and I will be in London on Tuesday. CtL (Mike) may well be heading down towards Plymouth on Tuesday evening but I'm not 100% sure
Old 4th June 2012, 08:45 PM
Many thanks for that but took Nollywood's advice not to stress and not to use use WOT! Got home in just under 6 hours! EMS light still showing but will get it checked out.
VMT to you and Mike for the weekend. Both of us really enjoyed it. Will be back for more!
Old 4th June 2012, 08:55 PM
47p2's Avatar
You can have a go with my Vag-Com if you need
Old 4th June 2012, 09:09 PM
Thanks for the offer John, I may well get back to you though i have never used the software and havent a clue how to read the results. (unless it's Janet and John style.)
