Old 29th June 2012, 03:03 AM
kal_ay's Avatar
kal_ay kal_ay is offline
Interesting thread
http://www.r8talk.com/forums/60-main...ke-valves.html
2002 D2 S8 Misano Red
1996 Volvo 850R Estate Red
2013 Mercedes C63 AMG (taxi)
1991 Lotus Carlton Imperial Green
Old 29th June 2012, 05:56 AM
Looks like simple fix- install extra injector in intake to spray some fuel in to clean up build-up, maybe a bit smaller then stock injector and wire it to fire together with one of main injectors. 1 extra injector for 8 cylinder car would be 12.5% extra fuel which would be near the limit of adaption range but if you put smaller injector ECU should be able to adapt to extra fuel.
Old 29th June 2012, 08:55 AM
Interesting reading.... Couple of the posts on there mention additional injectors... Still a ****-poor system though if it cakes up that badly... Probably good that I bought my sootchucker
Old 29th June 2012, 09:02 PM
I para-read the frost couple of pages.
It's annoying, but nothing like as costly as say a gearbox fault.
Seems nailing it regularly helps.
Like I needed any more reasons....
