Old 12th July 2012, 10:16 PM
Hi Pete,
I cant comment on your specific problem or if it is the same as this tread but I can point you in the right direction on this:
Originally Posted by A8Pete View Post
How would I extract error codes from the ECU to confirm my problem?
You need to read them either using a generic ODB-II code reader which will give you numerical fualt codes, which you can then search for information on.
Preferably use VCDS (aka VAGCOM) which gives a more descriptive output. It's not cheap to buy (ebay versions don't work very well!) but it works well, where are you located? Maybe someone nearby could help out or point you in the direction of a garage who could read the codes for you?
Old 12th July 2012, 10:45 PM
47p2's Avatar
47p2 47p2 is offline
I'm hoping it is a similar solution by changing out the fuel filter. It hasnt been changed since my ownership so its something that needs to be done regardless.
Im completly new to audi ownership and fault codes etc. How would I extract error codes from the ECU to confirm my problem?
Im going to change the fuel filter as per this thread. Is an Audi genuine filter a must or are the after market ones as good?
I had a peek under the bonnet today. I assume the diesel filter is the one on the drivers side of the engine bay underneith a piece of carpet, with what looks like 4 hoses are connected?
Stick with Audi filters, it saves a load of hassle in the long run.
Not sure on your engine where the filter is but once you have the new one you can compare, but it does sound like you are looking at the correct part
You will need to fill the new filter with fresh diesel before fitting the pipes, this makes for easier starting and prevents running the battery flat trying to pump the fuel up to the engine.
VCDS aka Vag-Com is best for reading and clearing codes, costs around £270 and you require a laptop but if you are keeping the car then it makes sense to invest in one
Nite Blue 3.0L SE Quattro
Old 13th July 2012, 11:52 AM
A8Pete A8Pete is offline
Thank you all for you advice.
I am Nr Orpington in Kent.
I have ordered a filter from Southern Motor Factors. Its an original for £36. I need a filter anyway so I figure why not start here.
If this doesnt work then I need to get the fault code out of the car.
I have the car fir a year now, so I was thinking of getting another A8 but maybe the 4.2 Diesel this time. Are the VCDS aka Vag-Com the same for both these models. I wouldnt want to spend now only to find it wont work on the next car?
Thanks for the tip on priming the filter. Thank you.
Old 13th July 2012, 01:21 PM
47p2's Avatar
VCDS and Vag-Com is the same thing and will work on most if not all Audi/Volkswagen.
There is plenty on here with inside knowledge of VCDS/Vag-comm who will be able to help you in choosing the correct product
Old 13th July 2012, 05:57 PM
I changed the fuel filter today but unfortunately it didnt work. So I guess its going to be something more expensive.
I'm Petts Wood, Orpington, Kent. Anyone Nr me that has the diagnostic leads etc that would be willing to help?
Old 13th July 2012, 06:07 PM
Doh, I've been in Docklands all week, and Maidstone this morning, with my lead
Back home in Harrogate now though, and not due down south for some time...
Old 1st October 2012, 11:17 PM
maglite's Avatar
maglite maglite is offline
Originally Posted by A8L Chick View Post
All fixed - Fuel Filter LOL
I was just having a read of this thread from start to finish. Now I feel like I've just come off a roller coaster. As I've just bought my D3 3.0 TDi, I get really paranoid about any warning lights. I'm so glad it was just the fuel filter and nothing serious. Phewwww I need a after reading all that.
Audi A8 D3 3.0 TDi
Peugeot 406 2.0 HDi Executive
Old 2nd October 2012, 07:17 AM
sloss's Avatar
sloss sloss is offline
Hmmm, I thought it wasn't the fuel filter....
I'm prolly missing summat
Old 7th October 2012, 10:22 AM
A8L Chick's Avatar
A8L Chick A8L Chick is offline
What you've missed is that I started the thread originally. My fault was fixed by the fuel filter replacement. This thread has been bumped by a fellow user having similar issues, unfortunately replacing the fuel filter hasn't worked for him.
07 Silver D3 A/S8L Quattro S8 front end, Xenons, Bose, Bluetooth, Voice Control, Autodim mirrors, Heated folding mirrors, Double Glazed Windows, Electric Rear & Side Blinds, Black leather Comfort Seats with front memory seats & mirrors, Front & rear heated seats, Interior/Exterior light pack, TV.I.M, AMI, Parking sensors Front & Rear, Air suspension (soon to be lowered), Keyless entry & Start/Stop, 4 zone climate control, Power Boot Open/Close.
Old 8th October 2012, 07:26 AM
sloss's Avatar
Ah, yes, this is where I picked up that it wasn't the Fuel Filter....
I remember it was the FF on yours.....
Really must concentrate a bit more
