Old 24th July 2012, 10:09 AM
david@a8parts david@a8parts is offline
Director at A8 Parts
You might find it easier to prise out the centre vent above - it is just pushed in so comes out easily without the need to undo anything - use a flat blade butter knife or similar and work it out a centimetre at a time at each end. Once you have it out there should be just enough cable on the vent to settle it upside down on the dashboard then you can simply push the switches out from behind the wood trim.
It might sound a long winded way but the switches arent that easy to get out from the front in our experience
At Work to Break:
2001 TT 8N 1.8T Quattro with a loud exhaust!
2000 A8 D2 3.7Q Non Sport Ming Blue
1999 A8 D2 4.2Q Non Sport Santorin Blue
2002 A6 C5 Allroad 2.5 TDi Silver with Black Leather
2001 A2 1.4 TDi
2006 A6 C6 2.4 Quattro Avant Canyon Red
At Work to Drive:
1997 S8 Pearl White Solar Roof, Electric Heated Rear Seats, Blinds, Bose, Cruise, Headlamp Wash, Ski Hatch
1998 Audi Cabriolet 2.6, Air Con, Electric Roof, Leather, Hard Top, Headlight Wash
2008 Fiesta Sportvan x2
2002 Transit 2.4 LWB
2007 VW Crafter Recovery Truck
2013 VW Caddy Highline, DAB, Heated Seats, Touch Screen Stereo, Headlamp Wash and Webasto with Telestart
2010 RS6 Daytona Grey, Twin Pane, Sunroof, Adaptive Cruise, Soft Close and some extra horses.
At Work to Hire:
4x 6 Berth Sunlight Motorhomes
Old 24th July 2012, 11:37 AM
Karstad Karstad is offline
i removed the vent and it was no problem, thanks.
Nothing wrong with the switch tho I'm all out of ideas now..
Old 24th July 2012, 07:29 PM
sloss's Avatar
sloss sloss is offline
Use a multi meter to find where you have 12volts or not as the case may be.
As you have the switch out how did you test it?
How did you check the relay?
I'd start at the foglamps themselves - there should be 12v across the 2 wires with ign on, switch on and sidelights on.
Old 25th July 2012, 01:36 PM
i compared the switch with the rear fog light switch, the relay i don't know how to test. but thought since the rear switch works then the relay is fine?
Old 25th July 2012, 01:44 PM
sloss's Avatar
I can't remember the D2 layout but it surely isn't the same relay for front and rear as you can put front fogs on without the rears.
Use a multi meter to see what you have at the switch. See if the live is switched properly by the switch.
I'd still start at the lamps themselves - could be as simple as both bulbs blown at the same time.
Old 25th July 2012, 02:19 PM
D2 Facelift has a 'control module' which is the size of 2 relays somewhere in the Passenger footwell relay box.
Its basically 2 latching relays that are driven by the two 'push to make' switches in the dash and drives the fog lights, front and rear. Theres not much to go wrong, but if its not bulbs or fuses, then changing the module would be my next option....
Old 25th July 2012, 04:12 PM
bulbs are ok, fuse is ok, no idea about the relay but since rear foglight works with that relay i think its fine. Don't really know how to check a relay properly.
