Old 18th September 2012, 05:13 PM
As far as I know self levelling rear suspension is hydraulic on D2 and runs from power steering pump.
Old 18th September 2012, 05:27 PM
71camaro 71camaro is offline
Well, I'm unsure about any of that since we didn't get that over here, but I wouldn't want anything else running off the engines. These are pretty standard compressors for this sort of setup. They fill the tank very quickly.
Front struts are here so I hope to fab and install them today. I think I'll have the rear mounts done and the bags in as well.
Old 18th September 2012, 05:31 PM
Pretty sure the D2 rear suspension was hydraulic.. There are power steering pumps with additional outputs for it.
Old 18th September 2012, 07:42 PM
47p2's Avatar
47p2 47p2 is offline
I don't know why car manufacturers can't make the compressor run off the engine the same as trucks. I don't ever remember having a problem with air suspension in a truck with this set up and the millions of miles I drove them
Nite Blue 3.0L SE Quattro
Old 20th September 2012, 02:40 PM
Roger the hydrolics. Didn't realise that. Given that MTM ran a Supercharger of the front of the engine there is plenty of opportunity to run a compressor. I have an article somewhere where a guy converted an A/C compressor to air. I'll dig it out when I get home.
I've added this to the sticky.
Old 20th September 2012, 04:14 PM
Don't have time to post the full write-up right now, but here's it on the ground. I'm pulling out the bags again and modifying them to go lower...
Old 20th September 2012, 04:19 PM
sarg sarg is offline
lower?
It looks too low as is, and desperately shows the need for spacers or wider wheels too
2025 Hyundai Ioniq 5 N
2020 BMW M340d xDrive
Old 20th September 2012, 05:00 PM
lower?
That's the beauty of it, I can raise it 6.5 inches from there by pressing a button.
Clearly this isn't how it will sit when finished, I have wheels and tires for it, but why would I mount them while still doing body work and the like?
Old 26th September 2012, 04:57 AM
Haven't forgotten you all, but I've been so busy with getting the car ready for a show of late I haven't had time to post updates. Assured they will be coming.
Old 26th September 2012, 07:45 PM
Night Train's Avatar
Impressive, most impressive (to paraphrase Darth Vader)
Other vehicles
Oh Yes....... The '98 PF S8!
