Old 29th September 2012, 04:45 PM
Do you get any suction on the pipe when you activate the locking?
I don't think so. The actuator works fine if you blow/suck into it manually, but not when connected to the pipe - so I assume there's no suction from the pipe.
If you suck/blow down the green pipes, then the doors lock/unlock, so is there a manifold somewhere where the pipes for the fuel flap, boot lock, etc come from?
