Old 1st October 2012, 09:33 PM
Somerandomguy's Avatar
You can go to 5570 from anything with the 3 disc version of the upgrade. I went from 10 something to 5570 in one hit...albeit i had to run some of the discs a few times.
I would go for the cd cleaner too?
Just a thought, you could try copying the cds to coputer to verify they are ok...i just downloaded mine so it will work with CDRs.
If you have an ami, it could be that your ami and cd are on the same address. Some Kits dont ground pin 4 on one of the connectors so they are both on he same addresses, so you could also try pulling the power on the ami to test this.
