Old 16th October 2012, 08:35 PM
if you have above 3000 it should work but always better to update to the latest version.
if you do update- make sure you do the entire update, not just relevant parts, and remember that its quite likely you will run in to component protection, probably the bose system will go, so you will also need a quick trip to the dealers to get rid of it
Old 19th October 2012, 08:34 PM
MAM MAM is offline
My bluetooth ecu has arrive, so I will try to get this fitted over the weekend to ensure that it works fine. I may embellish the fitting instructions with pictures if I can.
Deep Green 2006 '56' A8 4.2 SE, B&O & Exclusive Interior
Extended Aluminium, Oak Sepia Wooden Trim, Extended Leather
Green Exclusive Dual Colour, Heated Comfort Leather Interior
Green Alcantara Headlining, Pillars, Rear Shelf, Door Inserts
Green Trimmed Mats, Seatbelts, Steering Wheel, Centre Armrests
DAB, Freeview, ACC, 4-Zone Climate, Soft Close, Electric Blinds
