  #38
Old 29th October 2012, 07:58 AM
That's progress so far - will take some pics of the rails as I get them off. Any tips from anyone that's done it before? It looks like the wires go through the frame so no idea if there's a connector I'll see when I've undone the torx screws, or will I have to cut and rejoin the wiring?
Adrian
There's a connector above the rear view mirror IIRC. You'll need to remove trim above the doors (remove front and back grab handles first) to feed the wires through. You can feed the wiring down the trim at the side of the windscreen, unless you insist on going the same route as the original which is then along the top of the o/s front door, down the B pillar, back towards the driver's footwell......
