D3 - Body and Exterior Bumpers, bonnets, glass, trims - Everything outside |
Took it all out and refitted it today and all is good. It turned out to be a bit of trim in the channel had popped out. Thanks for you excellent advice.
2004 A8 3.0 TDI Sport Brilliant Black - now gone |
any chance you have a quick guide and what tools i need to remove the window and frame...? thanks in advance |
D2 Removing door trims is HERE Removing and installing rear door window is HERE ![]() or look at THIS for info on more areas D3 Removing door trims is HERE Removing and installing rear door window is HERE ![]() or look at THIS for info on more areas
Confidence is the feeling you have before you know better . . . . ![]() Audi A8 D2 3.7 Quattro Sport 1999 FL - Melange 2nd Place Winner - A8-Freunde Annual German Meet 2012 at Edersee 20" x 9" Bentley GTC Wheels with 385mm W12 Front Discs & Bentley Caliper Covers, Front Lowered on Coilovers, Xenons, Combined DRLs and LED Foglights to modified OEM front fog lamp position, Alcantara/Leather, Full Black Alcantara headlining + pillars and blind shelf, Bespoke Flat Bottomed Sports Steering Wheel, Dark Myrtle Wood, Autodim Mirrors, Bose, Blinds, Digital TV, Ski Hatch, Modified rear exhaust section for extra V8 Burble ![]() Audi S8 D2 Final Edition 2002, Avus Silver with Red Leather Interior Tiptronic with Sport mode button, Sony rear entertainment package, Bose sound system, Audi Navigation Plus, 20 inch Final Edition alloys, Full Cat Back Stainless Milltek exhaust, giving a great V8 burble ![]() Audi A8L D2 4.2 Petrol with LPG - Ebony Black Audi A8L D4 FL 4.0T Petrol twin turbo - Havana Black Audi A2 1.6 FSi Sport - Dolphin Grey with Votex body kit and Red Leather Interior and some other A8's A8L's and Mercs Last edited by Architex_mA8tey; 3rd January 2013 at 04:36 AM. |
OMG thanks your a life saver lol.
and its a d3. |
I also remved the mounting panel underneath, but not sure if this is actaully necessary.
Tool wise, youll need various torx drives and a star drive (either M10 or 12 from memory) for the screws 4,5,6,7 in the diagram. You do need to remove the outer door seal, which is glued to the door at the top. I used a trim tool to unclip the clips first before breaking the glue so that i didnt tear any of the rubber. I would also get a few replacement door clips a s you will break one or two, and make sure that you "reset" the clips prior to refitting as they wont go through the mounting holes otherwise and make sure the seals are fully seated around the window.
thanks for that.
and ive got a full torx/star set from machine mart so ill be ok with tool the side of things lol. its the technical bit but the diagram looks straight forward enough and i got little brothers that has patitence so yeh im sorted lol. and the seal is it just the top? or is the actual whole door seal from the outside glued on? |
The seal is the one that goes up the side of the door that is glued, at the top Near screws 5 and 6, it is continuous over he top of the window frame so you will need to pull it out from the frame to release it, or at least that is what i did.
Links no longer work?
Sadly no.
They look like dead links. Shame.
