Old 26th February 2013, 06:04 PM
carterleeds carterleeds is offline
it seems my SW version is not inbetween the uodate versions. however i did notice the H02 instead of H11 like yours. does this matter aswell?
Address 61: Battery Regul. Labels: 4E0-910-181.lbl
Part No SW: 4E0 910 181 HW: 4E0 915 181
Component: ENERGIEMANAGER H02 0160
Revision: 00000000 Serial number: 00000000001122
Shop #: WSC 00000 000 00000
VCID: DDB51D477DA1
well when i first rang up, a guy said sorry i cant take the REG plate i can only input VIN numbers so i left it because with the facelift upgrade i used autotrader for s8 reg plates. so anyways went in the following day and lance was there, and he happily took the reg plates and inputted them into the system and i got what i wanted.
Old 26th February 2013, 07:18 PM
not sure what the H02 / H11 difference is, the tsb doesnt mention your very low software revision, it only states that 0240 didnt have an issue, but above did, it maybe worth a punt anyway, it shouldnt cost much and they can check whether your batterys still good and for any other drains at the same time.
you notice at the end it says how to check its Ok, if there is still an issue to track the part thats affecting it.
Old 26th February 2013, 08:13 PM
Also looks like Limoncello's is a C rev hardware, may make a difference to the problem too.
I'd guess the H02 is a hardware revision 02 which if there was 'original' then H01, then H02 would lead us to C
