Old 8th March 2013, 07:55 AM
ulfilias ulfilias is offline
RanjS8,
Hi there, for sequential multipoint, which is what this kit would be, then the injectors get places as close to the origionals as posible.
EG
http://www.gasautogas.co.uk/projects/14.jpg
Lee
Old 8th March 2013, 10:51 AM
RanjS8 RanjS8 is offline
Default Manifold
Cool in that case it is just the intake manifold that will be needed which would most likely just be a straight swap for the existing manifold....don't have to worry about the heads.
Btw I don't actually that setup cos if you have an issue with the coil packs or want to change the spark plugs then the LPG injectors points are in the way.
I had a setup where the LPG injector setup came from the centre of the manifold....it meant that servicing the car and any misfire issue were easily resolved without disturbing the LPG system.
Ranj
