Old 22nd June 2013, 12:25 PM
Davie b Davie b is offline
Default Sat Nav problems
Hi Guys ,
i cant seem to get the satnav to work , i can input a destination ok but then when i set off nothing happems apart from the screen saying "destination" and showing an arrow which changes direction on the screen . when i select route it shows nothing with any relevance to where i am , it looks like it thinks i'm in scotland or something
I also get a warning saying "Position is located outside of the digitised road network"
occasionally the screen goes a bit mad like in the photo .
I have a disc inserted which i have also attached a photo of ,
any ideas anyone
Dave
ID:	6289   Click image for larger version
Old 22nd June 2013, 12:43 PM
Aerial failed maybe? What does it show as your current position and how many satellites is it picking up?
Old 22nd June 2013, 12:45 PM
How do i do that
Old 22nd June 2013, 01:20 PM
Done it ,
definitely looks like a GPS arial issue , not picking up any satellite's , so it looks like i'm in for a replacement , can anyone tell me if the disc i have is the most up to date for that system ,
cheers
Dave
Old 22nd June 2013, 01:27 PM
Found the manual?
What system is it?
Disc looks like a standard Blaupunkt Tele-Atlas non-DX disc.
The very last version of that is the "2007 Final Edition" which is 2 disks IIRC (England & Wales, Scotland & NI).
You can buy a new one for about £80 http://www.bluespot.co.uk/car-audio.aspx/map-cdrom-uk
Adrian E on here is good at supplying backups.
I could probably do one of Disk 1 at a push but don't have a non-DX system any more to check it on before posting.
Old 23rd July 2013, 10:49 AM
Greg66 Greg66 is offline
My cheap, quick and effective aerial fix here: http://forum.a8parts.co.uk/showthrea...1510#post21510
