Old 30th September 2013, 01:19 PM
Originally Posted by GH77 View Post
Hi,
Thanks for the response. Mine is a FL model so the warning signs appear in the top section as yellow 'dot-matrix' images. I think that's different to PF where there are individual bulbs for each warning in the bottom grid of indicators? So, on that basis (if I'm correct about PF / FL), it can't be as simple as just bulbs?
Seems strange that the car isn't even thinking to make the oil level part of the check sequence yet the washer level warning is despite it being known to be faulty . . . . .
Any ideas?
PF is the same showing warning lights on DIS but there was no oil level warning on PF, only oil pressure. Maybe a coding issue for instrument cluster as it's possible some engines might had oil level sensors while others did not.
As for windscreen washer lever then it must be either level sensor or you never got that low on the level for it to show warning.
