How many hours would you think?
2003 Daytona Grey RS6 2000 Silver S8 2005 A6 1.8TQ Premium 1993 Audi S4 2.2 TQ MTM 330 (my first love!) |
The veteran guys on quattroworld say there is nothing in the rack to wear out. Its a rack-and pinion, there is nothing to play in there (unless somehow you tortured it to death and ground all the teeth down?). You either tighten using the adjustment bolt, or change the tie rod ends. Or check the 3 rack mounting bolts are tight. Why would you change the rack?
The rack is actually a pretty common failure on VAG cars, surprised not seen more threads on them here.
Can't remember exactly, but mine was p!$$ing out PAS fluid, something to do with some seals/o rings gone, which in turn split a rubber boot which let loads of crap in and killed the rack. As for time, it took me, my brother and DIY Dad about 6 weekends and it was a bitch of a job, but at the time, Northampton Audi said it would be about £1700 (mostly labour), DIY cost £300-£400 or so all in. |
yes I forgot about all the power steering bits, I guess by the time you pull it to replace seals/pistons etc, you may as well put back a new rack, or a remanufactured one at least.
Apparently this place is good, not sure if there is a good place in the UK. New rack price from Audi is ridiculous, close to £1000. http://forums.quattroworld.com/a8/msgs/44931.phtml also check out quattroworld they covered a lot of rack problems. could be inner tie rod ends? Last edited by Goran; 21st January 2014 at 10:13 PM. |
I don't recall exactly, but think I got an exchange unit from TPS, wasn't mega bucks, but it's all the other little bits that you need too, steering wheel sensors and the like, getting it all re-calibrated at the end.
The difficulty with the change is that it's just damn difficult to get to, that's why the costs are so labour intensive. I'll have a look tomrrow in the old file, see if I've still got receipts |
Thanks guys I will tighten the bolt when I next have it in the air - I am going to put new bushes in the ARB as well.
The reason for changing the rack os due to massive freeplay in the steering..
Its pretty crappy to drive since it feels like a oldsmobile from the 60's.. I will try to tighten tje nut since averything in the suspension is only about 1 year old (all oem stuff) Strange thing is that the freeplay in the steering is only noticable when engine is running and barely when turned off.. ![]()
