Clive, don't you trust in the forum ?
![]() Sure, there is a solution, but only for the VAG garages themselves. The program is called ELSA Win, but it's forbidden to show to costumers and also to use it as a private worker. But anyway 50% of interested Audidrivers have it ![]() Here are some pics. It's located right there under the cover (couldn't find a matching pic, so I had to take an internet pic) ![]() If you remove the air intake tube you can see the sensor. You will have to remove a plastic clip which is shoved in. (not on the pic) ![]() ![]() This is the part seperated. ![]() The sensor is only plugged in, so you can pull it apart. You will find there a small amount of cooling water, which needs to be cold, so you can work properly. So let your engine cool down some hours. Greetz and good luck, Chris. ---------------- Now playing: Goldfinger - Get Up via FoxyTunes
![]() Audi S8 manual, 1996 <- much fun Kawasaki ZX9-R 2001 <- much more fun always remember:ficken! Last edited by ChriS8; 18th August 2009 at 03:30 PM. |
Yes, of course!
![]() Anyway, excellent write-up and what are those thingies going into each bank of your engine...?? ![]()
Present: S4 B8 avant, fully loaded, MRC Stage2, Milltek non-res, KW springs Past: S8 D2 FL, S2 ABY coupe, RS6 C5 saloon, RS4 B7 saloon, S4 B5 saloon, S4 B6 avant, all gone but not forgotten ![]() |
Hi.
No one of these pix shows my own car ![]() It's the car of a friend of mine, where I changed the part. The first pic shows a 3.7 fitted with LPG-injectors. On the other pics you see those ribbed tubes are also LPG-tubes to make it sniffing liquid gas ![]() ---------------- Now playing: Goldfinger - Spokesman via FoxyTunes
![]() Audi S8 manual, 1996 <- much fun Kawasaki ZX9-R 2001 <- much more fun always remember:ficken! |
